Question about DISH Network 322 DTV Receiver
Dish Network - Loss of signal after smart card upgrade.
I have a Dish Network model 301 unit. After upgrading from the yellow card to the blue one last month, the unit constantly loses the signal and has to reaquire. I have two SW21 switches, connected to separate rooms, and have tried both. I have also tried my spare set of LNBF's. The System Info and Check Switch tests always pass. The signal meter shows an average of 75 on both satellites (110 & 119), but the signal suddenly vanishes (no fade) then reappears. Customer Service had me run the Check switch test again, then said "That ought to fix it", but it didn't.
  • krebs830 Sep 05, 2009
    Thanks! I tried hooking up an older receiver that I hadn't used in years, and even with the ancient smart card it was able to aquire both satellites (though it only displayed a handful of channels) and there were no drops during the time it was on. I shut it off when I went to lunch, and it must have done a software update because when I turned it on again it wouldn't acquire anymore. I'll see if DN will activate it with the new card.
  • 404 Answers
Hi I will be more than glad to assist you in this concern.. Since you did already all the troubleshooting to fix the problem and according to the customer service, just run the check switch and test, that should fix the problem, but it didnt. The blue card that your refering is the g3 smartcard, it started when u insert to the 301 receiver.. It could be a bad smartcard or the receiver is bad, If you have another solo receiver in the house, just to isolate the problem, try to hook up the other solo receiver in the room where the 301 receiver is hook, run a check switch and test to the other solo receiver, once its done check your sat and signal, once its ok, cancel all the way out and it should acquire the sat signal..it will show attention 015 and let it finish the progress until it download the programming guide.. once u got a picture and the problem still exist with a different receiver. the problem is with the receiver and the receiver needs to be replace, if you call on dish network tech support, tell them that you try using another receiver and install to the room were the 301 is located, so that they wont do a troubleshooting again.. that is.. if you have another receiver to test and isolate the problem, but if not request for a service call so that they will send tech to your house.. please feel free to get in touch.
Posted on Sep 05, 2009
Only one satellite signal on vip722 dvr
Hi there! My name is Kimberly and I forma part of the Social Media team with DISH. I apologize for the delayed response and for the inconvenience you have experienced. It is my pleasure to assist you. At times when you are experiencing signal loss there may be lots of things that could be causing it, for example: bad weather, mis-aligned dish, lose connection, or bad receiver. You can follow this link http://www.mydish.com/support/complete-sig-loss?WT.svl=gsearch_results to help you troubleshoot the issue. If you need further assistance please feel free to contact me directly at kimberly.escobar@dish.com
Kimberly Escobar
Social Media Representative
DISH L.L.C
Apr 05, 2013 | DISH Network 301 DTV Receiver
I have a dish tv s7070 and was wondering if there is a way to change the time of the auto sw software upgrade. At the moment the upgrade is set for 3pm, however I quite often watch something during that...
brentcopeman
Depending upon your receiver model, you can change the time the updates take place. Press your Menu button on the remote to bring up the Main Menu. Press 8 (Preferences) and 4 (Updates) for our duo receivers and newer solo receivers. You can arrow over to the Time Set to change the time the updates occur.
The older receivers, model 301, 311, 381, Legacy receivers, etc., doesn't give you the option to change the time of the download. I hope this helps.
Ray Calo
DISH Network
Apr 25, 2011 | Televison & Video
I have an old echostar receiver, but i was going to buy the HD dish Vip 612 DVR. I wanted to knwo if the new DVR will take my saterlight card? and can i manually upgrade my LnB to a HD version?
Hey there, ihacharya! I saw your post and would like to offer you assistance. You are going to need to upgrade your dish satellite to a newer model as the LNBF on the one you have isn't capable of receiving HD signal. You can email me your account number so that I can look into that for you. My email address is michael.lemar@dishnetwork.com.
Hope that helps!
Mar 25, 2011 | DISH Network ViP 612
It just our of the blue said that "our smart card
If you are still receiving this error message try removing the smart card from the receiver for 10 seconds and re-insert firmly with the color side up and arrows facing inward.
If that doesn't resolve the issue you will likely need a receiver replacement.
Nick Franta
DISH Network Customer Service
Feb 21, 2011 | DISH Network 311 DTV Receiver
My dish 811 receiver won't download guide info. Do I need to reset and how?
Pull the smart card out of the unit and turn the unit off. then turn it back on and replace the card. this should reset the unit. It will take a minut or so for the unit to read the card and aquire a sat signal. If this does not work, simply call Dish network and they can walk you through any other options.
Nov 25, 2010 | DISH Network 811 HD DTV Receiver
Which size of the dish i want to fix for my my new receiver model kaon from dish tv
Guest
We would need more information to assist you. Do you want to know the type dish you can use to get satellite signal? Please elaborate more and we would be happy to assist you further.
Ray Calo
DISH Network
Jun 20, 2010 | DISH Network 301 DTV Receiver
Dish Network "Blue" Smart Card upgrade... Now get only "015"
The solution is usually a simple one and that has been suggested already but I will ask you to try one thing first. Remove the new smartcard and do not put one in. If the receiver still displays a picture and yoou can get to menu 611 run a check switch. After this is performed cancel out of the screens and re insert the new smartcard. Once the system comes back up perform the same steps as you did before with the smart card removed. If this fails you can try the solution they offered which was to update the sofware. There is no reason your software should be outdated if you were using this receiver before the new smartcard but try anyway as it may SOMEHOW work. Using the remote turn the receiver itself off. Allow the receiver sometime to turn itself back on-this could take awhile so plan this when you leave for work or are going to be gone from the house for sometime so you do not get bored waiting for this to occur. If the receiver has not turned back on in 45 minutes or more then the receiver will either need replacing -which i suggest- or they will try to send you a new smartcard if you talk to Cust service. Tell them you want a service call to fix the receiver. While you have them on the phone verify your receiver number and the new smartcard number which is on the back of the card and ask them to send a hit to the receiver. If the receiver has not been associated with the new smartcard or if the smartcard was not loaded with all of your programmming this should fix the issue. Thanks for using Fix Ya.
Feb 22, 2009 | DISH Network 322 DTV Receiver
510 DVR has to reload sat signal when accessing recorded events.
There was not a software upgrade in the last month for the 510 according to Dish Network. With that being said the issue is more than likely a bad hard drive. If you have to replace the receiver ask about a non dvr model that supports an external hard drive. This will allow you to keep from paying the dvr fee every month and allow you to have better control of your recordings eg. more record time, saved recordings if receiver needs to be replaced etc. There is a 39.99 one time fee for Dish to enable this feature but it is well worth it in my opinion. You may also want to check out the line of Sling media they have available also if you are an avid TV fan.
Feb 20, 2009 | DISH Network DVR 510 DTV Receiver /...
301 Power Problem
you might have a grounding issue or electrical power. dish receivers need a specific amount of volts, what you can do is take an extension cord n connect it to the rcvr and take the other end of the extension cord n plug it in on another outlet in another ROOM, then see if it powers on , if it does something is wrong w/ the outlet even if u have A tv or other appliace plugged in, if it doesnt turn on then call dish network n get replacement receiver
May 13, 2008 | DISH Network 301 DTV Receiver
DISH Network 322 DTV Receiver Logo
651 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
