Question about Toshiba 50H81 50" Rear Projection Television
No picture no sound and power light blinks.
No picture and no sound power lamp blinks?
  • BatFastard Dec 10, 2007
    Just wating the game and all of a sudden .....CLICK..... the power light on the front it blinking and no pic, and no sound
  • originaljrs Dec 19, 2007
    Toshiba 50H81... TV worked fine. Shut it off and then 30 minutes later attempted to turn on again. Relays click as if it wants to power, but after 10-20 seconds, no pic and power light on the front of the unit flashs. :-(
    Read something in a Tech Bulletin that cold solder joints could lead to blown fuse. The joints are on the bottom side of the power circut board and are the negative terminals C809 and C810 (I believe). Checked these joints, but they looked good. The one fuse I found right by the AC cord also looked good (which makes sense since the unit does actually get power; it just doesn't fire the projectors).
    Any more thoughts?
  • 4,402 Answers
Did you check the supply fuses to the convergence ICs? Did you check the output resistors
other wise i would replace the convergence ic first.
Posted on Jan 08, 2008
My id5220 television power light blinks but no picture or sound
1,the lamp ballast is failing
or the mother board is failing
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Feb 16, 2014 | HP Id5220n 52-inch 720p Dlp Hdtv sliv Lamp...
I have a Sony KSDR60XBR1. Beginning today, when I hit the power button the power/standby light blinks green approx 50 times and then begins to blink red 5 times. The picture is black and there is no...
Sounds like your lamp has failed. May not be physically blown but the 5 blink code indicates either the lamp or ballast has failed. Normally its the lamp. Good Luck!
Nov 21, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Picture goes out after 3 seconds then may come back on then off again
If green light in front of TV blinks while picture goes off and comes back then its symptom of weak lamp that need to be replaced.
And if green light does not blink in above process then let me know.
Nov 23, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Rca lamp replacement, still no picture, power light still blinks.
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
Jun 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
Toshiba 50H81 50" Rear Projection Television Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
