Question about Teac Reference DR-H300
My teac ref500 amp switches its self now and then and will not switch back on for 5-20mins, can you help
  • 4,234 Answers
This is a good indication that the amp is geneating too much heat. There are protection circuits inside that will shutdown the amp if it gets too hot. You will need to determine what is causing the excessive load on the amp to make it generate that heat. Look for crossed wires or problems in the speakers. This amp is designed for 4 ohms (I think) and a load less than that will still work, but cause the amp to work harder and generate excessive heat.
Please keep us posted.
Dan
Posted on Sep 05, 2009
Fault finding
It sounds like blown output transistors
Apr 23, 2014 | Teac Audio Players & Recorders
Will not switch on
Probably an electrolytic capacitor blew... should be obvious if you remove the case. The tops blow off or split... may leave residue.
Mar 22, 2014 | Teac AG-980 4 Channels Receiver
Not switching on!
A short has transpired before the fuse. Now in protect mode. See a tech.
My teac amp overheated now it won't switch on
Wait for it to cool. Try again tomorrow, or give it a few hours. If it still does not work it may need to be serviced, or replaced.
Mar 16, 2014 | Teac Audio Players & Recorders
I'm trying to clean my self cleaning I am getting an F91 code? Can you help
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%$%$%
Jul 01, 2010 | Kenmore 46123 Stainless Steel Electric...
Teac AG v6200 wont stay on
Check your speaker wires, if they are crossed somewhere then the system protects it's self.
Jun 22, 2009 | Teac Audio Players & Recorders
Teac PL - D3200 unlock coce
Multizone code for Teac PL-D3200
Here is the procedure to unlock your Teac PL-D3200 to play all zones of DVD's.
Using your remote control:
1. Switch power on 2. Open the dvd tray (leave it open with no dvd in it) 3. Press "stop" 4. Press "734466" 5. Use cursor to scroll up or down until it says "Region 0" 6. Press "OK/Enter" 7. Switch power off 8. Switch power on
It will now play all region DVD's! :-)
Apr 14, 2008 | Televison & Video
Teac A-H300 Amplifier
I found the problem....one thread of one of my speaker cables was touching the backboard of the amp and shorting out - problem solved!
Mar 30, 2008 | Teac A-H300 Amplifier
Teac Reference DR-H300 Logo
80 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
