Question about Whirlpool Duet GHW9150P Front Load Washer
F 14 or 14 F reading
My washer will not work
    President:
  • 1,776 Answers
This error indicates that the central control unit had problems receiving data. This code can be associated with a power glitch. The recommended course of action is to unplug the unit for two minutes and see if that clears the error. Other than that the only remedy is to check the electrical connections at the control board and the control board itself. Very sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 04, 2009
I have an ariston washer dryer combo. today I turned it on to do a wash cycle. the knob no longer clicks or shows the times of other cycles. I've turned it off and on a few times but nothing helps
Ariston armf 125 washer dryer combo - YouTube
? 4:14
www.youtube.com/watch?v=zPtG5Q3qQ3Q
Oct 23, 2010 - Uploaded by troykm Rinse cycle. Correction - it does do 3 rinse cycles!! :-)
[PDF]Instruction Manual - Ariston Appliances
aristonbrand.com/media/WDG-8629-User-Manual-19510586801_AU.pdf
WASHER-DRYER ! This symbol reminds you to read this instruction manual. ... from its packaging. 2. Make sure that the washer-dryer has not been damaged.
Sep 22, 2015 | Washing Machines
The soap compartment has water left in it
does the unit work? if so, dun worry about the water. unless the soap has not been gone into the wash?? do not use powder! these are liquid soap washers! lol.
Apr 13, 2014 | LG 14-inch Front Load Washer/ Dryer Top...
I have a am-14 hobart washer. having problem with rinse temp indicator. it is fine for the wash then the temp gauge is jumping around, could it be the thermostat?
Your rinse temperature sensor that is a tiny probe in the water piping (top rear of machine) needs replaced. Hobart part # 00-294692. It costs about $84.
Oct 19, 2012 | Hobart Dishwasher Am-14 Commercial Dish...
E 14 bosch washing machine!! aaagghh
i keep getting E14 on my bosch on my washing machine sometimes it works and other times fills with water then E14 comes up could anyone please help me .......
Mar 04, 2011 | Bosch WFK 2401
Screen reads UE? what is UE?
UE stands for Unbalance Error. If the washer has tried to spin numerous times, tried to redistribute the load itself between each attempt, and still not been able to get the load up to full speed without experiencing an off balance condition, it will finally stop and display the UE code. This is most often the case when a heavy / bulky item(s) are being washed and the spin speed is set very high. When washing these items, set the spin speed to low. The machine will most likely be able to handle that. If you want them spun out faster, then AFTER the washer has made it through the cycle on low speed spin do this: Turn the power back on. Without selecting any cycle, just press the spin speed button, selecting the next higher spin speed. Now press start, and your washer will just do a 14 minute or so pump and spin.
For super wet heavy loads, if you cannot even get the washer to go through a cycle on the lowest spin speed, you may have to wring a bunch of the water out of the clothes by hand before doing the 14 minute cycle thing.
Apr 11, 2010 | LG WM-2277HW Front Load Washer
My washer has 14 mintues left and it is blinking 14
you can try to unplug the machine for 30 minutes, let it reset itself that way. I'm not sure that'll work but it's worth the effort. What do you have to lose?
Aug 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Problem Magtag TL
UC means the washer cannot spin. There's a bulletin out this.
The clutch is likely the cause of these error codes, preventing the unit from spinning freely. A new clutch was introduced in production in March 2005 to improve performance and should reduce these error codes.
1. Visual verification can be made of a malfunctioning clutch by observing the lifter operation in spin. The lifters will rotate up to one complete rotation just prior to the tub starting to spin counter clockwise. Should the lifters continue to rotate while the tub spins, examination of the clutch will be necessary.
2. Inspect the 14 wire plug in the control console for loose red\white- pink- blue\white from the P3 connector. Also inspect the wires and connection point on the Tub Displacement Sensor for corrosion. Measure from PK to Wh/Bu at the P3 connector. The voltage should be approximately 1.5vdc when the tub is centered, 3vdc when the tub is pushed to the right rear of
the cabinet and 0vdc to the left front. Any variances of these voltages, the 14 pin harness connection, tub displacement sensor, and sensor connector should be checked.
Jan 05, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Black spots on white laundry
is the washer noisey when spinning? If so its probable that the main bearings are worn, & losing the original grease into the wash tub. At 10-14 yrs old its probably not woth fixing (assuming parts are still available)
Oct 19, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
48 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
