I have all ready down loaded adobe to get my
I have all ready down loaded adobe to get my check stub from deltacom and I can not remeber what to put in to call it back up
    President:
  • 252 Answers
Hey guy u might find that in TEMP folder. This is the folder in which each and every file is downloaded automatically from any website. the complete address is C:\Documents and Settings\username\Local Settings\Temp
Posted on Sep 14, 2009
  • 66 Answers
Are you having problems locating the Adobe Reader installation utility that you downloaded somewhere and Reader is not installed yet?
If so, you can search your computer for files that have been created during a certain time period. Open up Windows Explorer. Click on the Search button (or select File/My computer/ Search.. Click on "All files and folders". Click on "When was it modified?". You have several options here - select the most appropriate such as "Within the last week". Click on "Search".
You will be looking for a file with a name like "AdbeRdr910_en_US.exe". Once it's found, you can stop the seach. Double-click on it to start the install.
Once it's installed, you'll have Adobe Reader listed in your programs (select Start/All Programs). You might also have an icon on your desktop depending on your install choices.
I hope this helps!
- Susan
Posted on Sep 04, 2009
How do i get the axle stub out of the transaxle of my 97 vw jetta
drive out cv joint out of transmission using a hammer and brass punch.
Sep 25, 2012 | 1997 Volkswagen Jetta
We put the swivel hub into the wrong end of the sockets
I'm assuming you put the front wheels on from the wrong side. You need two large screwdrivers to slip down between the top stub of the wheel and the tube of the frame to press the two tabs in to release the wheel. I use a short piece of pipe that slips over the stub and pushes the tabs in.
Feb 18, 2011 | Bugaboo Frog Stroller
Unit shakes in spin mode
check to see if clothes isnt evenly coating the drum ,, is unit level remeber cabrio lid is slanted so you cant put a level on top lid and level unit must use the side of washer front to back on each side ...
Jan 28, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Down loaded up grade for adobe reader stoped
Try to reboot to Windows Safe Mode (press F8 before Windows boots) and remove Adobe from Add-Remove Programs in the Control Panel and delete the file with virus.
Check your PC with online virus scanner (trend.com).
Download Adobe Reader from Adobe and reinstall.
Dec 11, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
Acrobat 7.1 shuts down after opening
Installing later version of Adobe Acrobat is sometime creating compatibility issue with previous installed Adobe Acrobat Pro.
Make a deep search for your condition on Adobe KB: for similar problem I had to Reinstall Adobe Pro AFTER an update of Reader free Sw.
Check this entry
Dec 29, 2008 | Adobe Acrobat 6.0 Professional for PC
Editable forms with Adobe reader?
With adobe profesional you can make a PDF form, and send to the recipients. They can fill the form with Adobe reader and send it to you back, but only the data will be sent to you, not all with the pdf.
You can collect the data with your adobe profesional. Your programmer of medical paperless system can make the program to put that data in your database.
Here is the simple procedure:
1. Create form: Open adobe prof, menu advance --> Form --> create new form. You will go to Adobe design to create the form, there you can also retrieve your scanned document.
Don't forget to put "submit button" and your email address.
2. Then save as pdf form. It is ready to be send to your recipients.
3. The recipients will fill the data and send to you by pushing the "submit button".
4. You will receive the data in your mailbox, as an attachment of email. You can use adobe prof to collect it, example to put it in Microsoft Excel.
Go to menu advance --> form --> Create Spreadsheet from data files. A dialog box will come out, put in the files you received from your recipients. then go on, you will have the Excel data.
For put it in your database of your system, your programmer should create a program/ included in your system's program.
For Guest, to fill up is easy, just open the pdf form with Adobe REader, fill it and click the submit button.
Apr 15, 2008 | Adobe Acrobat Professional 7.0 for PC
Printer womt print Adobe pdf file
Hi , Have you checked with -
1. uninstalling and re-instlling the Adobe application once more?
2.the spooler - opn run on your computer and type down "net stop spooler"- let the command window close - then again pen ru and type down " net start spooler " and let the DOS / command window open and close again. Try taking the print with the printer in the ready status.
3. usbcable detection
Step 2 and 3 will not be most effective if the other applications are printing fine.
Try uninstalling and re-installing the Adobe application.
Or else you have to contact the Adobe vendor for further issues. It could also conflict if you have older version of IE in your computer.Becaus Adobe 8.0 is the latest version that might conflict with the older version of IE
Apr 08, 2008 | HP Officejet 4215v All-in-One Printer
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
