Question about Cell Phones
Synchronize vrbt330w
How to synchronize phone book
Dials numbers from phone book but does not connect
Do you have synchronization of the phone book running when the phone and the car kit pairs each other?
Did you pair the phone to the kit without using a menu?
Did you try to go into the menu settings pair with phone and see maybe your mobile.
I do not have the combination you have with the mobile therefore i can't simply propose test available to ensure the diagnose.
Please let me know.
Dec 25, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
How do I load and coordinate my MS Outlook address book and calendar with my Blackberry Curve 8330?
Here is how you do it:
1Install Blackberry Desktop Manager Softwarewhich included in your Blackberry Installation CD. If you don’t haveone, you may download software from Here
2Make sure you set an Outlook profile that the Desktop Manager can use.3Start the BlackBerry Desktop Manager.4Connect your Blackberry with your computer via USB cable and allow Blackberry device driver install.5Click on Synchronize in BlackBerry Desktop Manager.6Activate the Synchronize organizer data checkbox: BlackBerry Synchronize.7Click on the Configuration tab. Then, click on the Configure synch: BlackBerry Synchronize Configuration.8Check the data you want your BlackBerry being synchronized to. Choose CONTACTS, TASKS, CALENDAR, and NOTES databases.9Afteryou check each item, the software will ask which application you wouldlike to sync it with, you will choose OUTLOOK for all.10Nowgo back to the Desktop Manager. Make sure that the SYCHRONIZE ORGANIZERDATA check box is checked. And select the Synchronize now button at thesynchronize dialog to begin synchronization.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Dec 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Desktop manager for mac does not sync my contacts to BB 8700 only erases them at first sync however sync for calendar notes and tasks works . I have not unticked erase all contacts at first sync as I fear...
Back up information and data before changing any settings on your Mac computer:-
  1. If the BlackBerry smartphone is connected to the Mac computer, use the Eject option to remove the BlackBerry smartphone from the Mac computer.
  2. Close the BlackBerry Desktop Manager.
  3. Open Microsoft Entourage.
  4. On the Microsoft Entourage menu bar, go to Entourage > Preferences.
  5. Within General Preferences, click synchronize Services.
NOTE:-
1) To turn on contact list synchronization, select the Synchronize contacts with Address Book and MobileMe check box
2) To turn on calendar synchronization, select the Synchronize events and tasks with iCal and MobileMe check box.
NOTE:- When synchronize Services has been enabled and the OK button is selected, a new dialog window appears with the following choices.
  1. Replace Entourage items with synchronize Services items
  2. Replace synchronize Services items with Entourage items
  3. Merge Entourage items with synchronize Services items
Before the BlackBerry smartphone data is synchronized with the Mac computer, verify that synchronize Services is turned on in the Mac OS X isynchronize application. This is done by completing the following steps:
  1. Open Applications on the Mac computer and click isynchronize .
  2. In the isynchronize menu, click Preferences.
  3. If necessary, select the Enable synchronize on this computer check box.
Oct 06, 2009 | RIM BlackBerry 8700c Cellular Phone
Cannot sync anything with BB BOLD 9000
you can follow the following steps to sync Address book, calander, memo pad, and task.
1. open the desktop manager and click on Synchronize
2. Click on synchronize towards your left hand side of the screen
3. Again click on synchronize below configration towards the left hand side of the screen
4. then again lick on synchronize towards right hand side
5. Then you will get option to select device application and then click setup
6. Then you will get option sto select available destop application select Microsoft outlook and click next
7. Then it will give you synchronize options ( two way or one way )
8. In the next screen select outlook and click next.
9. Now it will give congratulations screen. click finish.
Aug 04, 2009 | RIM BlackBerry Bold Smartphone
LOST BOOKS
Found the phone number and spoke to a wonderful person who help me fix it.
Thank you anyway
Sep 02, 2008 | SanDisk Sansa e250 MP3 Player
Trying to hotsync my desktop and my 755, and I use Outlook.
if using verizon go into the wireless sync application and select settings> connection> advanced settings> and select enable other sync apps.
Apr 07, 2008 | Palm Treo 755p Smartphone
Synchronize my m240
The "please synchronize" error refers to the license for the library audio book you have on your device.
You will need to contact the content providers to troubleshoot the license issue.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa m240 MP3 Player
Corrupt Date Book Fixed
Updated Instructions Simple fix for a corrupted Date Book sync error (at least it worked for me on my Treo 650). 1). Turn off 'Show Calendar Event' in the Phones 'Options - General Preferences' menu. 2). Turn off phone. 3). Set the Date/Time to the maximum limits (12/31/31) in Preferences. 4). Open the Calendar and view the maximum day 12/31/31. 5). Select 'Purge - (Delete events older then 1 week)' in the Calendars Options menu. 6). Reset the Date/Time to the current day in Preferences. 7). Hotsync (Desktop Calendar overwrites handheld). 8). Hotsync again to make sure you don’t get the error (Synchronize the files). That’s it. =============================== Outlook Calendar The attempt to open the database failed. Date Book application database is not found. Please invoke the Date Book application on the handheld once and re-synchronize. OLERR:05-0001 OLERR:0D-0004 OLERR:0D-0001 - Not Synchronized Outlook Calendar synchronization failed OLERR:15-0002 OLERR:06-0001 ===============================
Sep 07, 2005 | Palm Treo 650 Handheld
Cell Phones Logo
215 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
