Question about Alpine Car Audio & Video
Alpine 7982 no code with unit
Nos stock item no manual no code to operate it alpine 7982 cannot turn on unit with out code
  • Michael Kovalik III
    Michael Kovalik III Sep 05, 2009
    hi and thanks for the fast reply , there is 1 to 6 on the numbered button side of hte unit . did it come with a remote? if so can i use one from an alpine 7969 to enter code?i haveone here from a old unit i had . it displayed code right away on the bench should i still wait till 90 mins before trying the master code anyway?
    mike
    great !code worked thank you ! . too bad units broken , cd mechanism takes the 3 disc mag and reads all three cds and repeats that over and over . tray comes out and in repeatedly .
    thanks again
    zeus407
  • 3,741 Answers
As the company service center has not provided the codes online.because its their monopoly.but this system has worked for many users try this -------- You need to leave you radio with pwr on for about 60 to 90 minutes,then the display will show CODE and you can try again,if you don't have the right code or nobody hasn't programmed any code try thisnumber which is a master code for this model code 0100
good luck
--------- thanks.please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Sep 04, 2009
Pontiac grand am wiring diagram
You will need the wire harness that is designed to connect to the stock stereo. Another option is to just install your alpine stereo in the car since you have the wiring harness for that. You will not be able to wire the harness for the alpine unit and have it match the plug type for your stock stereo.
Dec 12, 2013 | Alpine CDE-121 In-Dash CD/MP3/WMA/AAC Car...
Alpine CDA-9831 No Sound From CD's? My Alpine 9831 has always worked fine on the "Tuner" setting in my stock 3 series BMW. But recently I put a CD in for the 1st time and the head unit shows...
Are you using an amplifier? If so make sure you are using the blue/white wire to turn your amp on. The blue wire is power antenna turn on and turns off when leaving tuner mode.
Jun 28, 2011 | Alpine CDA-9831 CD Player
What is the security code for an Alpine 7982 in dash cd changer?
It wouldn't make sense to have only a single security code for every unit of that model, it will be tied to the serial number of the unit and only Alpine will have it. You'll have to contact them and you may have to somehow prove ownership since the code makes it unattractive for thieves to steal them.
Apr 20, 2011 | Car Audio & Video
Looking for instruction to operate an Alpine MDA-W905JB head unit in a Japanese car I just bought.
Go to the store and buy a mounting kit and wiring harness adapter that are for your car. There are alot to choose from and most are universal and come with instructions. You can get these at wal-mart or best buy. The mounting kit is meant to fill in the empty space left by the new aftermarket radio (your alpine). The alpine will have a metal sleeve around it. take this off and put it in the mounting bracket so it is flush. The sleeve will have little triangle shaped tabs on it. Bend these out so the sleeve cant fall out of the bracket or someone will be able to pull out your radio. Remove your stock radio by pulling off the trim around the radio. This is held on by clips, so be careful. There will be a couple of screws holding in the radio. Remove these and pull the radio out. Behind the radio there will be 1 or 2 wiring harnesses plugged into the radio. Unplug these. Then attach the wiring harness adapters you bought. These plug into the stock harness and have wires at the other end that are labeled. Wire the alpine wiring harness into the harness adapters that you plugged into the stock harness. If you want to you can unplug the harness from the alpine and wire it to the harness adapter before plugging it into the stock harness. The wiring diagram should be on the radio. If not the colors are pretty common.
RED = SWITCHED PWR LEAD (IGNITION)
ORANGE = ILLUMINATION
BLACK = GND
YELLOW = BATTERY LEAD
GREY = FNT SPKR RIGHT(+)
GREY/BLACK STRIPE = FNT SPKR RIGHT(-)
WHITE = FNT SPKR LEFT (+)
WHITE/BLACK STRIPE = FNT SPKR LEFT (-)
VIOLET = REAR SPKR RIGHT (+)
VIOLET/BLACK STRIPE = REAR SPKR RIGHT (-)
GREEN = REAR SPKR LEFT (+)
GREEN/BLACK STRIPE = REAR SPKR LEFT (-)
BLUE = PWR ANTENNA LEAD
BLUE/WHITE STRIPE = REMOTE TURN ON LEAD(FOR SUBWOOFER AMPLIFIER)
There may be RCA jack inputs in the back and these are for the subwoofer amp.
There will be a large black cable in the back and this is the antenna wire. Plug in the antenna wire from the back of the stock radio here. Yu may or may not need an adapter for this depending on the size difference between the wire and the hole it plugs into.
**Please note: if your car has a "premium" sound system that comes stock with an amplifier you will need to attach the power antenna lead from the alpine to the remote turn on lead on the harness adapter. If not when you turn on the radio/cd it will not turn on the stock amplifier and the speakers will not work.
I found this out with my 99 dodge avenger which has an Infinity stock radio. You can pop the trunk and look up at the back dash and see the small amplifier.
Once the radio is wired and the mounting bracket is installed, connect the harness adapter as well as the antenna wire. The new wiring harness adapter makes the wiring a little longer so you may have to stuff them back a little bit. Connect the harness from the alpine back into the back of the radio and slide the head unit into the metal sleeve until you hear a click. Before sucuring the mounting bracket and putting the trim back on it is a good idae to try the radio out so if there is something wrong you dont have to disassemble it again. When you buy the harness and bracket it will say on the packaging "nissan 84-94" or "Honda 83-99" or something similar. Look on the back for a complete list of compatable models.
Hope this was helpful. Please rate, and thanks!
Oct 17, 2010 | Car Audio & Video
Volume issue with Alpine CDA-7839 and Soundstream Continuum
Interesting that you have a Soundstream "The Continuum" amplifier. This is limited edition of the Reference 705 amp produced with a polished aluminum (not chrome) case. You have a very hi quality - Old School - amp.
Properly installed this amp should produce more than ample volume levels and certainly far more than a stock unit.
Because the Alpine head unit provides sufficient voltage to drive the amp, it is likely either the wiring, or, the way you have it set up.
The amp has a large internal capacitor bank and for proper operation, this amp must be connected directly to your car battery, prefereably with 4 AWG. (The amp is made with 4 AWG power connections.) Use high quality speaker wire run directly from each speaker to the amp.
If you have done the above, then it is probably the way you have it set up. The amp is sophisticated with many configuration options. Do not change any switch settings while the amp is playing. Ensure you have the appropriate inputs and crossover selected. Check the gain settings.
Jul 12, 2009 | Alpine Car Audio & Video
7982 Code and procedure
the factory code is 0100
Oct 17, 2008 | Alpine CDA-7998 CD Player
Blocked/locked alpine in dash receiver model 7982
You need to leave you radio with pwr on for about 60 to 90 minutes,then the display will show CODE and you can try again,if you don't have the right code or nobody hasn't programmed any code try this number which is a master code for this model code 0100
good luck
Jan 31, 2008 | Car Audio & Video
Car Audio & Video Logo
126 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
