Question about Intex Frame Set 12 ft x 30 in Pool with Pump
Intex above ground pool 15x48 filter pump problems
I have an intex above ground pool 15x48 and the filter pump does not seem to be sucking in or pushing out the water..Please lend me some advice
    Problem Solver:
  • 3 Answers
Get the air out of the filter housing
Posted on Aug 19, 2010
How do i connect the filter to an above ground intex pool?
skimmer hose to front of the pump top of the pump to the in of the filter the out of the filter to the return
Jul 09, 2014 | Swimline Hydrotools Sand Filter
New intex above ground pool sand filter has no way to vacuum it
i do believe that intex sells a kit to vac the pool ,it includes a plastic scoop that fits in skimmer to go to bottom vac wand
me i saw a photo of kit and made one out of an old vinegar container i cut the bottom off of and a length of old hose from a wet /dry vac and i use that to run around bottom to suck up solids (gotta fill hose first before connecting it )
Jun 05, 2014 | INTEX Sand Filter Pump
Return port of the intex pump is sucking in water at the top part of the nozzle
If the debris that is getting pulled in is floating, lower the inlet to about 3 to 6 inches under the surface of the water.
Mar 17, 2014 | Intex Above Ground Pool 12x30"" Easy Set...
Just replaced my 1000 GPM Intex filter/pump with the 1500 GPM. Worked great for about two weeks. Now it doesn't pump much with the filter in. Seems to pump fine without the filter.
The filter needs to be cleaned. the cartridge should be removed from the housing and sprayed on the o with a hose and sprayer. A strong, concentrated jet of water works best. I hope this helps.
Aug 15, 2011 | Intex 1500 Gph Swimming Pool Filter Pump...
Filter assembly Intex 15X48
The lower hole is for suction and the higher hole is for return.
The Pool Tech
Jul 07, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Pool pump shutting off/tripping the circuit breaker
What kind of pump are you using?
Sounds like the Intex is restricting water flow there by heating up your pump and shutting it down..
You may need to re plumb everything to handle the flow.
Intex hoses and fittings are different than the industry standards just so the can make you buy from them
Do what ever it takes to get good flow
Jul 01, 2010 | Intex Automatic Salt Water System for ...
How much time for a 15x48 metel pool
it varies from day to day depending on many factors like sun,heat, number of bathers and so on look at the manual and go from there.
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Jun 23, 2010 | Intex Automatic Salt Water System for ...
How much salt to start with a 15ft round pool
Assuming you have the Intex salt water system and the easy set pool, here's what the manual says:
15x33" - 65 pounds (80 for metal frame)
15x36 - 65 pounds (100 for metal frame)
15x42 - 80 pounds (110 for metal frame)
15x48 - 95 pounds (N/A for metal frame)
hope this helps!
May 28, 2010 | Intex Automatic Salt Water System for ...
Intex Frame Set 12 ft x 30 in Pool with Pump Logo
1,236 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
