Question about Proscan 26LB30QD 26 in. LCD HDTV
Dvd will not play
Pro scan Tv...hooked up with standard y,b,w cables...do not have remote for tv
  • Proscan Master
  • 8,457 Answers
Find the menu button left or bottom of ur tv find the AV mode or input in.If u hook up the RCA cable correctly.U should have DVD logo jumping around.Tries this Website.1-800-Remotes Factory Original, buy ur remote ur exact remote or very close to it.
Posted on Sep 04, 2009
How do I get dvd's to play on a 1990's model RCA tv without a tv remote?
You need an RF modulator and the proper cable(s) so that the DVD player can connect to the old TV coax input. See this video for the procedure.
TVs DVD Players How to Hook Up DVD Player to TV Having Only One RF or...
May 09, 2016 | RCA Televison & Video
I need to know how to hook up a d DVD/VCR to it.
Ur tv have a RCA INPUT holes like Y,R,W INPUT holes from the Front or the Back of the tv wright?Yes.U must buy or have it already a RCA components cable Y,R,W wires.Connected the RCA components cable Y,R,W wires to the DVD player Y,R,W OUTPUT holes and the other end of the RCA components cable wires Y,R,W connected to the tv Y,R,W INPUT holes.Now the tv and DVD player is on ok.Now u playing the DVD player contents Disc and push the INPUT modes on the tv like VIDEO 1 or 2 by the tv remote or manual button on the tv.Now u should have video picture of the DVD Disc contents playing.
Aug 15, 2011 | Philips Magnavox MT2501C 25" TV
Help. I got a used TruTech t200d for my nine year old. we were able to hook up and play on playstation 2, but are unable to get the tv to pick up the comcast channels. we do not have the trutech remote...
U able to go into the tv Menu?Yes,goto SETUP changes Pick CABLE and scan for channels for the Comcast CABLE channels.Or Try website like Remotes.com to buy an original tv remote.
Mar 04, 2011 | TruTech T2000D TV
I have a toshiba 36 inch television, magnabox dvd player and cable box hooked up. I can't get the television to channel 4 and I don't have the manual to get the remote for it to work. We use the remote for...
Oh yes clear on what your saying, Channel 4 needs to have signal to it during the scan!! So i hope this VCR or whatever you hooking up to it is set for channel 4 and its on and playing so a signal is marched threw it when your autoscanning. Without a remote this is a priceless fail i would recommend www.remotes.com get the remote for your TV and you should be able to navagate the menu fine. You also can put all you stuff on inputs to advoid the tuner all togeather.
Thanks we understadn what your saying and would like to help you in this manner but without a remote that works its will be hard to explain over email but please scan the channels when the thing is playing so it can detect a clear signal.
please do help us out by pressing the accept button for our efforts today!
Jan 12, 2010 | Toshiba 36A40 36" TV
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
How to set the telelvision to use a dvd,
On the remote ther is a tv/av button. Turn the DVD on and press play and the press that buttom on the tv remote and you will see your dvd playing. Have a good day.
Aug 04, 2008 | Philips Magnavox 27MS343S 27" TV
Television trouble
Might it be that you changed the input? Try pushing the input button on the remote.
Hope it helps...
Mar 04, 2008 | RCA F27442 27" TV
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Ds27510 tv sanyo
are you using the orginal remote that came with the tv? It should have a input button close to the power button
May 05, 2007 | Sanyo DS31590 31" TV
Proscan 26LB30QD 26 in. LCD HDTV Logo
96 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
