Question about HP Pavilion dv9000z Notebook
Our motherboard just died
Tech support is on the phone, they want us to pay for the repair.
  • 736 Answers
Not sure on the dv9000z but on many other laptops i have noticed that temperatures get very high inside .. if it gets hot enough then something will fail .. often the video chip . sometimes others .. there seems to be two problems .. first when you use your laptop on your lap (or worse yet on a bed or pillow) then the air intakes can be blocked .. it will feel hot when you are using it .. second and i cant for the life of me figure why this one is still a problem .. the pads that hold the laptop off of the table (so that the air intakes are not blocked) are so short that the intake fan does what they call an "airfoil stall" .. when the suction pressure gets to a certain point then the fan stalls (quits moving air or greatly diminished air flow) its just spinning it wheels without doing much .. .. of course the temperature goes way up .. on many laptops i have found a dramatic improvment in cooling just by putting on "stick on" felt pads that raise the laptop up just a little more .. high enough off the table top to allow the fan to do it job .. often you can feel a big difference in exhaust air temprature .. another way that really shouldnt be necessary but works .. is to mount the laptop on a laptop cooler .. thats a flat plate containing a fan or two that keeps the computer much cooler .. anymore when i see a laptop that has a history of similar failures, i suspect high heat as the cause .. unfortunatly it doesnt matter what fails .. almost everything is mounted on the mother board and no matter what the trouble is . its the mother board that has to be replaced .. if you check on the internet to see if many others are having the same trouble then you might want to insist on a free repair .. that has worked a few times sometimes not ..i like doing business with the companies that cooperate ..
Posted on Sep 04, 2009
    President:
  • 1,185 Answers
If it is under warranty or extended cover then it is free so contact your original supplier
If it is out of warranty and you have not taken out cover you are stuffed
Beep codes
Hello here is the manual:
http://www.motherboards.org/files/manuals/107/mk7vtapro11.pdf
Adobe reader is needed to read the content.
Here is a list of beeb codes:
http://www.computerhope.com/beep.htm
I would start to renew the power supply, and see if that helps.
Look also here:
http://www.computerhope.com/issues/ch000607.htm
Look also for bad caps on the mainboard:
If they are leaking like this, scrap the mainboard.
It does not pay, to let it be repaired.
Good luck
Feb 22, 2013 | Soyo SY-K7VTA PRO Motherboard
Why my callers cant hear my voice when they call me on myphone..but me i can hear thier voice
It helps more if you were to be more specific with the make and model. 9 times out of 10 it's a bad MIC. Most cell phones have the MIC soldered to the board. Some phones like the iPhone or Nexus One can be changed out easily by just replacing the part. The quick way to test your phone is to shoot a video and talk. If you play back the video and don't hear anything then you know 100% you need to replace the MIC. It should be a cheap repair I usually charge my customers $25 - $30. I wouldn't pay more then that. You can find a lot of repair techs on Craigslist HOWEVER be careful and use proper judgement when selecting a repair tech to take your phone to.
Aug 22, 2011 | Cell Phones
Replacement battery for VTECH IP 811 cordless dies fast
It seems like the phone uses a lot of power or you talk a lot on the phone. If your buying a cheap battery just remember you get what you pay for. This site here has some batterieshttp://www.shopping.com/xPO-Vtech-VTECH-V-TECH-Cordless-phone-battery-for-IP811-IP-811-NEW Otherwise check Ebay or Amazon. Hope I've shed some light on this for you. You might just wanna get a new phone.
Mar 18, 2009 | Vtech IP 811 Cordless Phone
My phone just died on me
your cell phones motherboard is totally damged & the motherboard acnnot be repaired it can only be changed. I dont know whether Ebay gives warranty or not IF they give its repairing will be free of cost but dont tell them how was it damaged.OK.if they dont give warranty then for its repairing you will have to pay lots of money
pls rate my solutions
thankyou
Feb 16, 2009 | LG KM500 Cellular Phone - Unlocked
Motherboard has died 3 times in 13 months
Hi there
Sounds like a generic problem you are having, get HP to change it for a different model if they will as you are entitled to under the consumers act.
Good luck with them
Jan 26, 2009 | HP Pavilion dv9000z Notebook
Motorola PEBL U6 keypad died
UOLACE - what that person said is ****.....if the keypad is dead then it can easily be replaced so take it to a better tech shop.
hartman - you should have it reflash to correct this issue
GUEST - try another battery and if that does not work then have the phone's firmware reflash
Jun 29, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Non powering
hi! the motherboard is dead. if the ac adapter light turns off when plugged in and if you unplug it, it will turn on, then the problem is with the motherboard. It needs to be replaced. Call Dell Tech support if you still have warranty to have the motherboard replaced or else, you have to pay for the repair.
Hope this helps!
Karlox
Dec 16, 2007 | Dell Latitude D400 Notebook
HP Pavilion dv9000z Notebook Logo
48 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
