Question about GE Profile Wizard DPSE592EAWW Electric Dryer
Dryer belt replacement
I have a GE Model DWXR473ET1WW dryer. Need assistance on belt replacement.
    President:
  • GE Master
  • 1,922 Answers
Put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Posted on Sep 26, 2009
My dryer's belt broke and I cant find the part
WE12X1001, WE12X1000, WE12M29 are the three different belts used on GE Dryers and if you go to
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher and do a search on these parts you will be able to purchase them directly from GE. You will need to look at your belt and pull the number off if your belt in order to assure you get the right one. If you require further assistance, please do not hesitate to ask.
Jun 14, 2011 | Whirlpool GEQ8858H Dryer
To replace the belt on GE Dryer DISR473DG1WW, we will need to open the back of the cabinet, right? Is there a repair manual showing the process? Does this dryer ship with a spare belt inside?
Hello, W/D here.
I'm not aware of any dryers shipping with a spare belt on board, but this may vary by region.
You are correct in that the back is removed to gain access to the belt. Disconnect the power first. If there isn't a spare in the cabinet (probably not), take the old belt with you to your local appliance parts supply house and get a replacement, or it may be ordered on-line. The belt number will be on the belt.
Here's a good website showing how your model is assembled. This site also has parts descriptions and prices; useful for comparison shopping. There is also usually a button-link to a free downloadable manual. Here 'tis: http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DISR473DG1WW/0432/0151200?pathTaken=&prst=0&shdMod=DISR473DG1WW
Another good site to check for parts is: http//www.appliancepartspros.com.
Armed with these items, replacing the belt will be child's play for you!
Best regards, (and please rate this solution), --W/D--
Apr 02, 2011 | GE Dryers
My GE DSXH43EA2WW Dryer is making a squeaking sound when running. Tends to get less noisey as the dryer continues to run
Hello
You will need to replace the dryer belt and inspect the belt rollers while you have it apart. If you go to the web link below it explains how to take apart the dryer to replace the belt, it has additional links to pictures and diagrams within the instructions. The first link is for replacement parts with diagrams of the dryer. Here is that link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130504&diagram_id=21844825#d21844825
The next link is the Do It Yourself Article on replacing the dryer drum belt. while you have it apart remember clean the lint and dirt out of the cabinet interior. Here is the repair link:
http://www.applianceaid.com/ge-dryers.html#belt
Jan 14, 2011 | Dryers
Cannot remove the dryer back to replace the belt. Model number is DCXR453EV0WW. Please assist.
The top lifts up then there are bolts to remove the front to gain access to the belt
Jan 04, 2011 | GE DRSR495EGWW Dryer
GE dryer model dbvh512efoww has burning smell
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your burning smell may be coming from your belt or an excess build up of lint in the exaust.
You will need to remove the vent exaust hose and clean it out, and also check the lint filter and discharge that is going to the hose for lint buildup.
Your other problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 28, 2009 | GE Dryers
Replacing the belt on general electric washing machine model WWA7304PML GOT IF OFF TRYING TO PUT THE NEW ONE ON
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. Diagrams M, D, or L under the General Electric section will show how your dryer belt goes back on. If you need assistance in determining how old your dryer is, post your serial number and I can determine for you. I hope this helps you.
Jun 09, 2009 | GE Washing Machines
Need some assistance with a DDE7200SBLWW/model ge dryer
If the dryer is getting hot but not turning, you most likely need a new drum belt. If the belt is ok then you will need a new motor.
Dec 03, 2008 | GE DBL333EA Electric Dryer
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Ge dryer
you need to remove the front panel and kickplate (if you have one) This will allow you to detach the front of the top of the dryer and you can prop the top up while you replace the belt around the drum, down to the drive belt. Here's a link for your make and model. It shows an exploded view of the parts of your dryer. http://www.partselect.com/MultiModels.aspx?ModelNum=dde7100&searchTerm=&RefineSearch=0. This can help you figure out what parts you might need and how things go back together. Good luck!
Jul 14, 2008 | GE DBSR453EBWW Electric Dryer
GE Profile Wizard DPSE592EAWW Electric Dryer Logo
611 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
