Question about Refrigerators
The refrigerator doesnt stay cold. freezers fine. the refrigerator will get cold if you don't use it for a long time
  • 4,059 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Sep 04, 2009
hiltonjug
  • 612 Answers
SOURCE: GE Refrigerator-Freezer side works fine/Refrigerator side not ok
You most likely have a defrost problem. Check the inside back panel of the freezer. See if there is ice built up. If so, you have a problem with the defrost. 85% of the time, it's caused by a bad heater. It could be the termination thermostat, timer or fan. If the ice is built up. Take the panel out and defrost with hair dryer. If you want, you can now check the heater and termination thermostat. It's a closed switch that opens on the rise. If you fix it your self or not, To save your food. You can replace the panel and turn the fridge back on, it will operate correctly for 3 or 4 days. This will give you time to either get the part and fix it or for someone to get out and repair.
Please rate solution and make it worth the while to summit solutions. Thanks
Posted on Aug 28, 2009
SOURCE: trubleshoot refrigerator staying cold enough
These fridgs lose their freon which is likely tke problem in part
Posted on Oct 16, 2008
rpbuice
  • 161 Answers
SOURCE: refrigerator/freezer not staying cool
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
If there is no frost on the freezer side it may be low on coolant.
Posted on Dec 21, 2008
whytfang
  • 170 Answers
SOURCE: freezer is cold but refrigerator isn't
Number one when you can always provide model number and make...it helps enormously in troubleshooting otherwise you get these long detailed threads...from an anal tech like myself.
Cold is a relative term....how cold...use a thermometer...and determine if the freezer...is at least..10-20 degrees or colder if not it is not cold enough...and here are some generic answers for that problem....I will list at the bottom of this thread...if it is
A. You will need to determine if you are getting air flow into the refrigerator side compartment..there is usually a baffle...that controls...the amount of air-flow into the frig side...it can be adjusted...if not it could be broken or have come loose...it is rare...
B. Is something blocking the baffle...as in food ...groceries...
C. The thermostat could be out of adjustment...and or going bad...(how old is the frig)..
D. Some newer units have a dual fan system..(but rare)..if the frig side fan is out...this could be the problem...
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. If this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that may have occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer and hold the button in above the door..(fan switch)...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of it being due to overfilling are slim...I have been in the industry for 35 years and that is what freezers do...which a lot of people don't realize is that freezers don't actually cool anything ..they just remove heat and when you remove all the heat all that is left is cold (like in space) and when heat is removed quickly frost can appear like when you blow your breath on a freezing cold window..then right your name....but I digress...any way..if there was an excess of heat due to a lot of new food in the freezer it would correct itself by one of the processes i mentioned above..and it would never result in Ice..you probably have one or more of the problems I mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which would delay or inhibit a defrost cycle..from occurring..unfortunately almost all of these problems require a tech...or a good handyman.
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: the refrigerator is not getting or staying cold enough. the freezer seems to working ok
Check the vent at the top of the shared refrigerator wall for cold air from the freezer. If not, then you can either replace the motorized flap inside the vent or prop the flap open with a stick or something. The manual solution won't harm anything. The motorized flap is an over-engineered solution designed to create service calls. :<)
Posted on May 21, 2009
My fridge is leaking water in the fridge then doesnt stay cold. Freezer is working fine just not fridge.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 28, 2010 | Samsung Refrigerators
Freezer gets hot around front edge and doesnt get cold enough..stays in defrost mode it seems
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Oct 16, 2010 | Hotpoint Energy Star HTH15BBRR
Fridgedaire freezer not staying cold. I can
did anyone help you with this problem? i have a similar problem but my freezer works fine in the summer. it does not stay cold enough in the winter. i keep the frige in my garage as a spare but it's not very helpful when it doesn't work! a repair person told me it was too cold in my garage for the freezer to work...not sure why, the frige part works fine. i'm looking into a blanket insulator from appliance zone to see if that will help.
Jul 25, 2009 | Frigidaire FRT17B3A Top Freezer...
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
156 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
