Question about Adcraft SG-813
Need replacement parts. Two bolts that secures the top plate to the rotation bar both broke (snapped) and I cannot remove the remains. Need new bar and bolts.
You will have to use a screw extractor to remove the broken off pieces that are still in the grill. You have to drill a hole into the remaining bolts and then tap or screw in the screw extractor. Turn counterclockwise and they will come out. Home Depot may have the allen head screws that hold down the bar.
Posted on Jul 20, 2012
Auger beater bar won't turn.
did you check the belt?
Nov 27, 2015 | Vacuums
Installing new belt
+>> Unplug the mains lead from electrical socket <<+
• Turn cleaner over in flat position.
• Release lower plate by rotating the 3 lower plate latches to the UNLOCK position.
• Remove lower plate and remove any dirt that may exist in belt area.
• Remove beater bar by gripping the belt side of the beater bar and carefully lifting it out.
• Remove worn or broken belt.
• Clean beater bar and the end caps.
• Loop new belt around motor shaft and beater bar belt groove.
• Reinstall the beater bar by inserting the end cap of the beater bar to the slots at both ends of th beater bar.
• After reinstalling the beater bar, turn it by hand to make sure that belt is not twisted or pinched and that all rotating parts turn freely.
• Reinstall lower plate by hooking front end of lower plate into slots on front of nozzle.
• Press lower plate onto nozzle and secure by rotating the 3 lower plate latches to the LOCK position.
Jan 12, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
How to change a belt on a Whirlpool washer model LA555OXTWO
I am not exactly sure on your machine, several places called it a direct drive unit but here are some directions I have found also.
1) Turn off water. Disconnect electrical supply and water hoses.
2) Remove agitator and cap from machine ( this is not always possible as the agitator gets frozen on the shaft, it just makes the job a little easier )
3) Lay machine on it's front. Protect front of the unit from scratches. Do not leave it over night on it's front as some oil will leak out the breather hole on top of the transmission.
4) Remove rear service panel
5) Loosen both nuts holding the motor mounting bracket in the slotted base plate holes. (see figure 1)
6) Rotate the motor to the right to relieve the belt tension and remove belt from motor pulley
7) After belt is removed from motor pulley, rotate motor to the left as far as possible to assure cam bar clearance.
8) The spin cam bar must be advanced to the spin position. Push up on the spin control solenoid plunger and rotate the main drive pulley until the cam bar advances to the spin position.
9) Remove the brake yoke spring from the gear case cover and yok. (see figure 2)
10) Remove completely the 3 support braces attached to the gear case and base plate. (see figure 3)
11) Remove the 2 pump mounting bolts. The pump hoses do not have to be disturbed. (see figure 3)
12) Remove the gear case mounting stud which has the spacer. remove spacer (see figure 2). Loosen the remaining 2 gear case mounting studs approximately 7 turns. (see figure 3).
13) Remove yoke retainer from yoke support. (see figure 2 for the types of yoke retainer).
14) The gear case can now be pulled down so that the belt can be slipped out between the top of of the clutch shaft and the clutch yoke. (see figure 4) and then through the space beneath the short stud; drop the belt from around the gear case.
15) Reverse the procedure in steps 15 & 13 to install the new belt.
16) Replace the pump making certain the pump lever is engaged in the notch in the agitator cam bar before securing the pump to the gear case ( see figure 5).
17) Grasp the bottom loop of the yoke spring with a pair of pliers and engage the spring with the hole in the upper gear case cover (see figure 2).
18) Replace spacer in short gear case mounting stud. Tighten the 3 gearcase mounting bolts ( finger tight only ). Next, set the machine upright and tighten the gear case mounting bolts securely. This procedure will allow the superstructure to properly align itself with the center post bearing.
19) Lay the machine on it's front to mount the 3 support braces to the gearcase baseplate. Tighten the bolts securely.
20) To adjust the belt tension properly, position the belt over the pulleys. Insert a hammer handle or some other lever between the motor mounting brackets. Rotate the motor to the left as far as it will go. Tighten the nuts holding the motor mounting bracket. Check the tension of the belt, it should deflect about 1/2 inch. (see figure 1).
21) Set machine upright. Reinstall the agitator, agitator cap, service panel, water hoses and connect electrical supply.
Mar 07, 2011 | Whirlpool Washing Machines
99 chevy venture front sway bar broke
The sway bar is pretty easy to fix. Here's a video that will show you exactly how to change the one in your Chevy Venture.">
Feb 22, 2010 | 1999 Chevrolet Venture
Replace front strut
You will need a strut spring compressor. You can probably buy a cheap one for about as much as a shop would charge you to install a new spring on your strut.
Sometimes you can even "borrow" these from your local parts store with a deposit.
It is probably faster to do it yourself than bring it to a shop.
You need to compress the spring before you put it in the strut housing. Directions should be included with the spring compressor kit.
Here's the general directions:
Take the two bolts on the bottom off
There may be a bolt holding the brake line in place (remove it)
Take the three bolts on the top off
The strut assembly should be free now.
Pull strut assembly out and set it on the floor
The top nut holds the top bearing plate and that holds the spring in place.
Remove the top nut
Remove old broken spring
Compress new spring and put it in place on the strut
Put strut top plate on and secure locknut
Release spring compressor.
Reinstall strut assembly in car.
Good Luck!
Apr 16, 2009 | 1998 Chevrolet Malibu
Replace front license plate holder
On my 92 ford pu, the plastic tabs snap into square holes in the bumper. They can be snapped out when there is no bolt in the hole by using a flat screwdriver & a little prying.
Apr 11, 2009 | 1997 Ford Expedition
Dyson 18 slim the rotating brush bar will not rotate. Was working fine until I got the edge of a tablecloth caught in the brush, pulled it out ok but now the brush will not rotate fast, but will rotate by...
If the DC18 has a proteted belt then it will have to be replaced by a Dyson engineer or repairer. If the cleaner has a removable sole plate where the beater bar is then remove it and replace the belt - sounds like the belt has snapped and needs to be replaced. if your DC18 is still relatively new it should still be under guarantee.
Mar 25, 2009 | Dyson DC18 all floors Bagless Upright...
Washing machine
Sounds like the agitator securing bolt is missing and what you see is the remaining washer (" a plate with a hole in"), if the bolt is missing the agitator should simply lift up to remove, the securing bolt is a 10mm x 40mm should do the job, you will need a 17mm socket and long extension to refit the securing bolt.
Mar 17, 2008 | Admiral AW22 Top Load Washer
Adcraft SG-813 Logo
95 people viewed this question
Top Adcraft Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an Adcraft Kitchen Appliances - Other Expert? Answer questions, earn points and help others
