Question about Car Audio & Video
Car Audio question how much thick should be the power cables for my 600watts rms sony xm-zzr3301 mono d class amp 4gauge or 8gauge should i connect fuse also with what amperage
  • 125 Answers
Bigger is better, recommend 4 gauge. 50-60 amp fuse
Posted on Sep 04, 2009
Testimonial: "thanks for assuring me"
Is my class d 800 watt amp brigeable
If it is a mono amp, it is already bridged internally.
Oct 13, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Which amplifier i should use with JBL CS-1205T
this sub woofer tube has a rms rating of 275 watts... try using a kicker or orion 600 watt mono amp to run this. the brand name is what tell you about how good an amp is for instance the names i just mentioned rate their amp by standard play frenquencies where as other lower brand names rate their amps by the max out put on certain subs at certain frequencies which may lower their impedance and create more power although you will never play your sub at those frequencies. as for the max power of your sub of 1100 watts that is more than like only at a certain frequency so always only double your rms rating of your sub to find max power handling.
Jan 29, 2011 | Sony Xplod Amplifier XM-SD51X - Class D...
My car is a 92 ford falcon when u play bassie music u can only just here it out side the car but when u pop the bot u can realy here it wat can i do to make it louder out side the car
crack the windows and drop the sony bull **** and get your self a nice mono block class d amp 1000 rms should be loud enough btw bild your stereo based on rms power not max power rms is the true power you got so like 2 500 watt rms 12s on a 1000 watt rms amp or just a 1000 watt woofer it will be jsut as loud as the 2 12s
Mar 30, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
Amp goes into protect when turned up.
that amp is only stable 2 about 4 omhs mono the powersupply shut dowm drawing t much current it supposed 2 2 fix this u need a 4omh load mono change speaker config so u get 4 omh or buy amp stable down 2 1omh can be expensive
Aug 28, 2009 | Sony XM-2002GTR Car Audio Amplifier
Sony xm-D9001GTR mono and kicker 4ohm dual voice coil
its a good amp but dont power ur amp at full put it at about half power
May 27, 2009 | Sony XMD9001GTR Car Audio Amplifier
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
