Question about GE WBVH6240F Front Load Washer
Our General Electric WBVH6240FWW Front Load Washer is making a racket while spinning?like it's out of balance. When empty, if I spin it manually, it goes around once or so then kind of gets caught and stops. Ideas?
  • 35 Answers
May be broken spider--assy. that supports drum. If so, toss it. Too expensive.
Posted on Sep 19, 2009
GE top load profile washer won't spin. It starts
The tub hangs on 4 support rods. Lateral movement is kept in check with 4 bungy cords bolted to the top of the tub. If that washer is not level the tub will hang to one side and the fancy controls will declare an error. Make sure all your rods are good (they drag the base of the machine when worn out and make a heck of a racket) and the bungys are not stretched and the machine is level.
Aug 04, 2012 | Washing Machines
During spin cycle washer drum knock and seems as if it is out of balance, even when empty
"spider" broken. Cast aluminum bracket that attaches shaft to inner tub is coroded. Spin tub and shaft assembly cost approx $300 to replace. Heard that parts may have lifetime warranty.
Sep 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
My GE WBVH6240FWW front load washing machine won't spin.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jul 01, 2009 | GE WBVH6240F Front Load Washer
Frigidaire Front Load Washer Making loud racket in last spin cycle
try pulling off lower acess panel. theres apump in rigth side corner . does it sound like theres something gaught in the squeeze the hose, try opening the door assy can you lift up on the inner basket. does it appear to have a bit of laterral movement???? how old is it???
Mar 13, 2008 | Frigidaire GLTF1670A Front Load Washer
The spin cycle
happymarried,
You said, I replaced my belt cuz it was worn now when it spins it seems like it might b off balanced it kinda makes a racket.
It is out of balance and or alignment .
Unfortunately you now need service or it will cause more problems to run like this!
Sorry that I am not there hands on to help you!
Bless You,
Huum
please give me a rating before you sign off our site
Thank you
Feb 13, 2008 | Frigidaire FEX831CS Top Load Stacked...
My frigidare glws1233a top load
Do you have this noise when operating an empty machine ? It could be cause an unbalanced load of clothes. Stop the machine, redistribute the clothes and re-start the machine. In case you still have this noise, the problem is with the transmition between the drive motor and the inner tub. Good luck !
May 22, 2006 | Frigidaire GLWS1233A Top Load Washer
GE WBVH6240F Front Load Washer Logo
605 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
