Question about Sony PFM-42B1 42 in. HD-Ready Plasma Television
Six flashes on self-diagnosis
Panel turns on for a minute or so then goes off. Standby light flashes six times. Apparently a PDP problem. Does this mean a board needs to be replaced to fix it? How much if a bad board?
It's been a good display for 5 years 8 months.
  • 2 more comments
  • raja2nv Dec 28, 2007
    I have the same problem!
    does any one know where you can buy the PDP PANEL?
  • raja2nv Dec 31, 2007
    Hi All,
    I have searched around the net for anyone selling a PDP board for sony, and that it cost $1100 Australian Dollars ex GST
    Does any one know where to find a cheaper board or someone that can fix this in Australia?
  • Bobanus Feb 02, 2008
    I have the same problem too. I have known that panels with this problem
    (6 blinks at startup) are replaced in US for free. Unfortunally I'm in
    Russia and nobody but myself can help. Please let me know if you have a
    solution for this.
    Thanks.
    solution for this.
    Thanks.
I HAVE A SONY PFM-42B1. NO IMAGE, THE SCREEN DON'T TURN ON .STANDBY LIGHT BLINKING CONTINUOUS. I SELL THE TV FOR PARTS , MAKE ME AN OFFER.
E-MAIL: xpressti@sbcglobal.net - Chicago Area -
Posted on Feb 22, 2008
I have the same problem too. I have known that panels with this problem (6 blinks at startup) are replaced in US for free. Unfortunally I'm in Russia and nobody but myself can help. Please let me know if you have a solution for this.
Thanks.
Posted on Feb 02, 2008
I have the same problem ... please let me know if there is a solution for this. Thanks
Posted on Dec 31, 2007
Light blinks 6 times but tv will not turn on I have unplugged it for a few minutes ad plugged it back in and still does the same thing
Standby light blinks to Sony TVs are fault indications. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
This is the fault to your Wega. If you want more details, check this.
Jan 03, 2013 | Sony FD Trinitron WEGA KV-34HS420 34" TV
6 times b;inking light
Check the horizontal output section circuit. Six blinks of standby light indicates:
  1. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Jun 16, 2012 | Sony Televison & Video
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Sony kp tv standby light flashing 6 times. Is this a problem I can fix, or do I need to have a service tech look at it?
Those are diagnostic codes:
This will sometimes be caused by overheating (not always). You will need to contact the manufacturer or a repair technician.
Jan 30, 2011 | Televison & Video
I was watching the news and it shut off on its own and will not turn back on. What do i need to check?
If you include how many times the standby light flashes, that will give a fault location. Not to worry, here is a list.
Hope this helps.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
Jan 23, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
My sony trinitron will NOT turn ON, and blinking standby light is constantly blinking... what is the common problem with this?
If you let us know how many times the light blinks, that will let us know whereabouts the fault area lies. Her is the list. I hope it is helpfull.
Jan 19, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Bravia KDL-52XBR9 wont turn back on red led flashes unless I uplug and plug back in. Did firmware upgrade to newest aa0143pn, still happening.
There is a error in TV.Count how many times blinking the red light.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" boards
Nov 16, 2009 | Sony BRAVIA KDL-52XBR6 LCD TV
Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
No power, standby light flashing
SIX Blinks
Jul 24, 2017 | Sony KDL-32S3000 32 in. LCD Television
My 61 In sony xbr flashes the standby light 5 times
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those, which you will see for each of these faults on a diagnosis screen described later in this article.
  • Eight GA_googleFillSlot("TL-IMU-Article");blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Mar 28, 2008 | Sony KP-61XBR48 61" Rear Projection...
Sony PFM-42B1 42 in. HD-Ready Plasma Television Logo
162 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
