Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Change the belt on the brush
Changing the belt for the cleaning brush
  • ruetney May 06, 2008
    i cant figure out how to change the belt
    Problem Solver:
  • 9 Answers
Dear Norrfam87,here is a website with the manual for your Bissell 7920.
http://www.bissell.com/images/UserGuides/7920.pdf
On page 18 and 19,they tell how to replace the belt !
I hope this helps,EarlsOK
Posted on Dec 08, 2007
Change a belt
You did not state your model or make so I can't explain how to change your model but most vacuums you must remove the bottom plate held on by screws that covers the brush roll, remove the brush roll and belt and reverse the process with the new belt. Some models have the brush roll held in by screws and/or brackets, some brush rolls slide down into slots. Replace the brush roll if the bristles are worn or frayed. If you are not replacing the brush roll remove the endcaps if possible and clear any hair or debris that has worked it's way in there.
Cogged belts are different from stretch belts and do not need to be replaced at least once per year like stretch belts do. You should still remove the brush roll at least once or twice per year to clean out debris. Maybe more often if it gets hair or strings wrapped around it which can build up causing friction and heat which can melt or damage the brush roll or even the nozzle housing.
Jan 29, 2017 | Vacuums
DC 07 brush bar not working
The brush is driven by two belts and a clutch. Your belts on the clutch are stretched. Their are several youtube videos for rebuilding and replacing a DC07 clutch. Just change the blets don't buy a new clutch. A lot cheaper to change belts. You might as well clean everything up while you gave it apart. Have fun.
Jul 07, 2014 | Dyson DC25 All Floors Bagless Upright...
Change Belt
Hair and debris works it's way under the end caps of the brush roll causing a restriction. If you can't clean the debris out and get the brush roll spinning greenly you may need to replace the brush roll.
Mar 25, 2014 | Vacuums
My Dyson in making a really awful noise.
You may want to open up the bottom where the floor brush is and check the condition of the belt and as to whether or not something is caught in the belt or beater brush. The owner's manual should provide directions on changing the belt. While you are changing the belt, give the beater brush a good cleaning and add some WD40 to the ends of the brush where the plastic holders are located.
If you find my solution to be of help, I would appreciate a Thumbs Up rating from you.
Paul
Oct 09, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do I change the belt? Do I have to twist the belt.
You do not have to "twist" the belt.
You should be able to find your answer at this URL:
http://www.bissell.com/product_search.aspx?searchType=main&searchtext=3522
Look at the users guide for information on changing the belt. I would suggest that while you are changing the belt, also take time to clean the beater brush, you have to remove it anyway to change the belt. Clean the brush as best you can and add some WD40 to both ends between the brush and the small plastic pieces that hold it in place with the vacuum.
Oct 08, 2010 | Bissell 3522 PowerForce Bagged Upright...
The rotating brush is stopping
Two things you can do. 1- Remove the brush as if you were going to change the drive belt for it. Clean the brush as best you can and spray some WD40 on the hard rubber/plastic pieces at both ends of the brush. Rotate the pieces to work the WD40 into the space between the pieces and the brush axle. 2- If you have one available, as long as the brush is off, change the belt.
This should get your unit back in operation. If you find this solution helpful, I would appreciate a Thumbs Up from you. Thank you. Paul
Oct 08, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The roller brush will not turn. The belt is not
Sometimes the belt can stretch cause the roller to not turn. Also make sure the roller brush is free of any debris.
Use this link to access your vacuum to change belt or clean the roller brush.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 27, 2010 | Hoover U5068-900 Sprint Upright Vacuum
The brush motor starts and stops during use
Is it the actual motor stopping or the belt that spins the brush that's slipping? if its belt slip, this happens, pretty common on all belt vacs, dirt and dust gets under the belt and causes it to just slip with no actual grip on the brush end. This slipping can also cause to much friction ware and actually changes the inner diameter of the belt so even cleaned it would still (maybe) slip so need a replaced belt.
But I'd take the belt off first and clean it as well as the heads it spins over then try it again. Make sure you unplug from the wall, a vac brush can and will take your fingers clean off.
Jan 01, 2010 | Hoover U8120-900 WindTunnel V2 Bagged...
Changing the belt
It is quite easy. Just take off the bottom of the vacuum encasing the roller brush. It should snap off or you may have to unscrew some screws and lift the cover off. Then remove the roller and clean it while you have it out. Now put the new belt on the motor shaft or pulley and slip the brush into the belt. Then replace the roller brush pulling the belt tight. Replace the cover and clean house.
Apr 03, 2009 | Bissell Upright Vacuum - The Pet Hair...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
134 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
