Question about Dell 2600 Notebook
Laptop won't turn on.
My laptop suddenly turned off and it will not turn on. The battery is charged but whenever i press the power button, nothing happens.
  • darkai210 Dec 09, 2007
    Here is exactly what happened. I was coping a video to my laptop from my flash drive. Then suddenly my laptop turned off. If you look closely you will see three lights(look at the arrow) on the front of the laptop. usually those lights are always on, as long as the laptop is not been shut off. Now when i press the power button those ligths won't stay on, they only flash, and neither will the computer. I did have the laptop on my bed, but now i moved it to a flat surface. it was not overheated and it is pluged in.
    Sergeant:
    Champion:
  • 362 Answers
Does it work when you plug it into the wall outlet. i need more info.
Posted on Dec 08, 2007
  • james kilgore
    james kilgore Dec 09, 2007
    it sounds like it might have locked up. do you have a startup disk made if so try booting up with the start up disk. not the recover disk. if it dont let me know we have to work through a few steps so i can find the problem.
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Laptop lost battery back-up suddenly.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 06, 2012 | Acer Aspire 5810T-8060 Notebook
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
I hadn't charged my Sony Vaio model PCG-61611L for a couple days. Then when I finally plugged it in to charge, it won't turn on. I even left it plugged in for a few days and still nothing. It has...
Try A Hard Reset
Remove the battery and charger/ac adapter/power cord from your Sony Vaio laptop, press and hold the power button for 20 seconds to discharge any residual current inside the laptop.
This clears your RAM and is like a hardware reset.
Replace the battery and charger/ac adapter/power cord
and turn your laptop on.
If that does't work try removing ram and reinstall. Sometime this works with these laptops.
Sep 11, 2017 | Sony VAIO VGN-AW330J/H Notebook
I have a mini laptop which shutdown by itself a sudden. attempt to power iton both with battery alone and on charger plug-in proved abortive. it will only blink the power LED indicator when power button is...
Hi
Thanks for posting in Fixya
1st of all did you try on the other laptop with the same model and make? if yes then did you check in windows if the battery of that laptop is showing it is charging?
Try to remove the main battery keep pressing the power button for 15 - 20 secs. then release it. now connect the charger directly to the laptop and try to turn on.
If you want to install the battery back do not insert when the laptop is running. Turn it off and then install the battery back and load windows later check if the OS shows that battery is getting charged
Jul 15, 2011 | Computers & Internet
PLSS HELP!!! i have a hp pavilion dv900, and my problem is whenever i use my laptop for just even 2 hours, my laptop suddenly shutsdown or better to say turns off mot likely when i pay rfolympic, a online...
How long have you bought your laptop? If it's still under warranty (specially the battery), bring it back to where you purchase it and tell them the detail. You have problems with your battery that's why you cannot fully charge it and it easily drain. The problem with 3 to 4 times pressing the power button is that when you put your power chord, it will take a moment for the battery to charge an enough power to start your laptop, but I believe nothing is wrong with the switch. It's basically a battery matter. Word of advise, if you have the chance to replace your battery, do not overcharge and do not keep the power chord attached to your laptop most of the time. Allow your battery to reach the lowest level once in a while. This will help you maintain a healthy battery.
Jun 04, 2011 | Computers & Internet
Hi my Samsung R530 will not turn on. I have the charger in and the battery is charged to 40% and the orange light is on to say that it is charging. I press the on button and nothing is happening, please...
Hi danielgardha,
I see that you are experiencing issues with your Laptop, you mentioned that the battery has %40 charge and that the adapter is plugged in on the laptop to the wall but still you get an orange light, but when you press the power button nothing happens on the machine.
  • Remove the battery and the adapter from the Laptop then press and hold down the power button, this is to drain power from the motherboard.
  • Once the power has been drained from the Laptop, connect the adapter back again but leave the battery out of the machine, then turn the system ON using the Adapter only.
  • If the Laptop turns ON using the adapter only then it is possible something is wrong with either the Battery or the motherboard of the Laptop.
  • Turn the Laptop OFF again then put the battery back in, then power the system again check if it will turn on with the battery and adapter in the Laptop.
  • If the Laptop does not turn ON when the battery is plugged in then you will need to have the system checked for a motherboard issue.
I hope that this will help.
mvincentc
Apr 25, 2011 | Samsung R530 Notebook
T20 wont turn on
make sure the battery is unplugged from the laptop and only hook up the ac adapter. If you can't get it to turn on then try anotherr knowng good working adapter and if it still can't turn on then the motherboard is bad and will need to be replaced.
Jul 06, 2009 | IBM ThinkPad T20 2647 Notebook
Dell 2600 Notebook Logo
47 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
