Question about Magellan Maestro 5310 Car GPS Receiver
The battery does not hold a charge for very long. I will leave it off for a week and the warning comes o that the battery is low and then shuts it off. is this normal? My other magellan would hold a charge indefinately in the off position
    Top Expert:
  • Magellan Master
  • 80,417 Answers
The batteries in these units last an average of 2 years, when the battery is worn out it makes no diff how long you charge it, u just need a new battery.
Posted on Sep 04, 2009
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
The battery doesn't hold enough charge to complete one brushing.
When the battery gets low again leave it on whith out using it and the battery will drain completely. Let it stay like that for a few hours. Then shut it off and charge the battery fully then check the prformance of the machine.
Mar 14, 2011 | Vacuums
My toshiba satellite laptop won't turn on. If I hold down the power button sometimes it will turn on for a few seconds, but then shuts off. About a week before this it would shut off without warning when...
I might just be the battery.
Look at your AC adapter and see if the light on it comes on when plugged in. If so then that should be good.
I could also be a dead battery that will not accept a charge. Replacing the battery could fix it.
If it happens again after the new battery discharges then it could be the connection on your motherboard is not charging the battery.
Apr 19, 2010 | Computers & Internet
Battery gradually discharges unless forced to charge
something is wrong withe your lighter so unplug it when the car is off also you may want to do a complete charging system inspection on your vehicle
Jan 06, 2010 | Garmin nuvi 205W GPS Receiver
I also have Casio Exilim EXZ75 I didn't charged it for almost 3 weeks and once I charged it, the red light flashes on and off... Then I inserted it in the camera... it still doesn't work... how can I solve...
kindly leave the battery for long duration in charging position let the red light blink and then see after like 16 hours or 24 hours if it works and charge otherwise change the battery with the same specs , and next time when u leave battery for long duration likea month or weeks charge it to full or half so it can hold some power to re charge again , ur battery is in Coma state nearly dead so it might come back or not
pls rate me well
Regards
Zohail
Aug 11, 2009 | Casio Cameras
One minutes Battery meter shows full, the next 0% Battery Low
Have you tried powering the phone off and removing the battery? Cleaning the charging contacts on the phone and the charger? Inspect the charging port to make sure there wasn't any damage from the fall. Then restart the device.
Hope that helps.
Apr 22, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Milwaukee 28V Lithiom-Ion Battery loses power in storage
It is not recommended to leave the battery installed in the drill while not in use. The system of the drill will eventually pull the battery down, especially if the battery has had a lot of use. When the battery begins to weaken it will not hold its charge as long.
If you haven't, try charging the battery, 24 hours max and then keep it detached from the drill for several weeks. Then try it aand see how much power you have left. If it is low or depleted, battery is weak.
Nov 15, 2008 | Milwaukee Drills
My new sony ericson w850i is having to be charged every other day even though sometimes I haven't used it for more than 1 or 2 text messages,when I plug the charger in (the one that came with it in the...
optimise charging means that it is charging.. try leaving it to charge for an hour or two. if it still doesn't work, then you bring it to a service center.
Apr 27, 2008 | Cell Phones
HS850 charge doesn't last long
Sounds like you've got a defective model. Mine lasts about 4-5 days before I have to charge it.
Apr 10, 2007 | Motorola Mobility HS850 Consumer Headset
Magellan Maestro 5310 Car GPS Receiver Logo
275 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
