Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PWO
I thought after my tile floor was installed it was off balance...So i re leveled it and i am getting a F 11 code, first i got a DL code, after the leveling now i get the f 11 code. It will run for about 2 minutes and then it starts beeping with the F 11. It also seems to do this if you use it more. I also took off the front panel and opened the drain thingy cleaned it out..and there was black sooty stuff in there..replaced it and now I am waiting. Please help Is this model a problem??
  • jordinary Jan 08, 2008
    I have the same problem with the Whirlpool duet GHW9150pwo. We think it is the door latch do you know the part number for this model latch
  • 262 Answers
No this model isnt a big problem but they do have some issues but they all do i work on all name brands and the whirpool is the one i like the most
Posted on Dec 22, 2007
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
Replacement: tub seal bellow/Whirpool Duet mod.#GHW9150PWO
Thanks for using FixYa. You can buy the tub seal bellow for your Whirlpool Duet from this link. Please accept the solution if the issue is resolved or post a comment for further assistance.
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9150pwo f11 error code
f11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor
Control Unit (MCU) cannot be sent correctly.
* Check Wire Harness connectors to the MCU, the motor, and Central
Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer not spinning
It's not really a solution but I checked my paper work from when I purchased the washer and found out that I got the extended warranty, so I have called in a service call.
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9150pwo code f h
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all
the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the
inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to
Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain
Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation
Don't get too deep into the washer itself and void your warranty!
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
You must press in the control lock for a few seconds to disengage it I believe. Try unplugging and replugging the the unit if that doesn't work.
Dec 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,815 people viewed this question
Dan Webster
Dan Webster
Sal De
