Question about Refrigerators
Freezer door will not stay closed when closing refrigerator door
  • 4,070 Answers
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
To replace it Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on Sep 04, 2009
  • 3,267 Answers
If the freezer compartment has somehow got an air connection with the bottom of the fridge. Hence on closing the the fridge door builds up a pressure inside and thus opening the freezer door...sodeep
4 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Posted on Jun 06, 2008
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Posted on Feb 21, 2009
lenwest
  • 150 Answers
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
Freezer door wont seal and stay closed
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Jun 06, 2008 | GE GSS25QSTSS Stainless Steel
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
305 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
