Question about KitchenAid KHMS147 Microwave Oven
The door handle is broken on model khms 105ebl0 kitchenaid
How do I get the inside panel off to get to the screws to replace the broken handle
  • 5,911 Answers
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Posted on Sep 05, 2009
Need to replace door handle for Kitchenaid over-the-range microwave, Model: KHMS2050SSS - 0
You usually get better search results by leaving off any dashes or spaces in a model number.
Normally you have to separate the door panels (as shown in the photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful literature and exploded view diagrams with part numbers here and you can order parts from the Pros here.
May 21, 2013 | Microwave Ovens
How do we replace broken door handle? How do you get to handle screws to take it off?
Normally You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 18, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How do I replace the door handle on a KHMS155LSS Kitchenaid microwave?
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
This should be a very simple repair that you can easily perform yourself.
If you have any questions, please post back and let me know. You can refer to this illustration, if you like, to assist you as well:
http://pcappliancerepair.com/model-display.php
Mar 19, 2010 | Microwave Ovens
Need microwave help, broken handle and more..
I doubt that just tightening those screws would have caused this problem, but if so, I would loosen them a quarter turn first.
Instead, my bet is there is now an issue with the door switches or mounts.
To replace the door handle properly, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
For more on door switches, see:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Jan 09, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Broken handle on Spacemaker microwave
The handle can be replaced without replacing the entire door, or oven. The part number is WB15X1309 and can be purchased at pcappliancerepair.com for about $45. Due to the age of your oven, I could only find it at a couple of web sites, and this was the cheapest price I could find for you.
Sep 08, 2009 | KitchenAid KHMS147 Microwave Oven
Handle broken
You can order a new handle off of repairclinic.com. You can remove the handle by removing screws. Some screws are under plastic cap on handle, others, have to be accessed from inside door or door panel
Aug 26, 2009 | Microwave Ovens
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 07, 2008 | Microwave Ovens
Kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Jan 27, 2008 | Microwave Ovens
KitchenAid KHMS147 Microwave Oven Logo
186 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
