Question about Sony PlayStation 2 (PS2) Console
Unable to read discs
No matter what game disc we put in it reads unable to read discs. It is a playstation two.
  • monkey112 Dec 08, 2007
    every game i put in it says that the disk cannot be found
    Problem Solver:
  • 6 Answers
  1. Solution based on a slimline ps2
  2. Check to see if a Music cd will spin in the console
  3. Open flip lid and examine the reset switch - check to ensure the switch is intact - you are looking for a small lever which is made of lack plastic. If its not there you need a new reset switch
  4. If the laser is not moving at all you will need to open up the console (WILL OBVIOUSLY VOID YOU WARRANTY!)
  5. Check the PCB switch at the rear of the console. This part connects to the lid of the ps2 if thats is broken you will need to replace - difficult to source but they are available
  6. Check the ribbon cable underneath the PS2 Laser for any signs of damages
  7. Check the ribbon cables x 2 which attach the laser assembly to the motherboard
  8. Remove the motherboard metal shield and test the SMD (SURFACE MOUNTED) fuses on the underside of the board use a multimeter for this
  9. If your console passes all these tests the most likely cause is a blown laser which is a simple part to source via ebay etc.
  10. If your new laser does not fix your problem then you have a blown RS2004 chip which is expensive to replace and usually not economical to do.
Posted on Dec 08, 2007
PS3 - Unable to read disc
Follow these steps when you are facing "disc wont read" problem
Step 1:Remove the disc from the system.
Step 2:Use a cloth to clean in small circles around the disc (not in a big circle going around the disc). Use DVD or CD disc cleaner if available. If you use cleaner, use a different dry cloth to clean the disc no more than three minutes after application.
Step 3:Verify that there are no disc-destroying marks on the disc. Deep scratches and chips in the middle of the disc can render a disc inoperable.As your Playstation 3 is used more and more, the lens that reads Blue-ray discs can become dirty. This will lead to discs skipping or not being read by the console. If you find this is happening on your Blue-ray discs, either movies or games, you may need to have your console cleaned. Be careful when attempting any sort of cleaning of your console, as improper handling will further damage the Playstation 3. Contact a member of Playstation Support for information on console maintenance.
Thank you !!
Jul 05, 2010 | Sony Playstation 3 (PS3) Console
Unable to read any discs
Try keeping off your system for 10-15 minutes and try again. If problem exists go to the shop from where you bought your PS3 and ask them for replacement of your drive or your drive lens. I think drive sounds better.
May 16, 2010 | Sony Playstation 3 (PS3) Console
Disc put in playstation 2 says it can not read the disc
You must get your ps2 checked I had the same problem back then cause my ps2 was over used
I just bought a new ps2 and know a ps3
May 16, 2009 | Sony PlayStation 2 (PS2) Console
Unable to read disc
just clean the lens or contact shopkeeper
Nov 04, 2008 | Sony PlayStation 2 Slimline Console
Call Sony @ 1-877-253-SONY(7669)
Aug 20, 2008 | Sony Playstation 3 (PS3) Console
Ps2 keeps saying disk read error everytime disk is put in no matter what disk is put in what can i do to fix
  • Confirm the disc is inserted correctly into the PlayStation 2 console (label side should be facing up when the PlayStation 2 console is in the horizontal position).
  • Confirm the disc is clean. To clean a disc, use lint-free cleaning cloths made specifically for cleaning CD/DVD discs, sold at computer software stores. When cleaning the disc, we recommend starting from the innermost circle, and wiping out to the edge in a straight line. We do not recommend wiping in a circular motion, as it may create more scratches on the disc. [Note: Other materials, such as a paper towel or a T-shirt, may also scratch the disc. If there are any scratches, smudges, or fingerprints on the disc, it may not function properly.]
  • Try playing different CDs, DVDs, and games on the PlayStation 2 console to see if the problem exists across multiple discs.
  • To determine if the problem is with the disc itself, try playing the disc on a different PlayStation 2 console (or a PS oneTM or a standalone CD/DVD player, if applicable).
  • Confirm that you are not using any game modification devices. Unlicensed devices such as game modification devices can interfere with the proper function of the software. We do not recommend the use of any game modification devices or unlicensed products[1].
Dec 17, 2007 | Sony PlayStation 2 (PS2) Console
Play station 2 won't read silver disc only reads blue disc
Hi Elvis,
The Blue back disc is CD format. The DVD laser circuit is giving you trouble. You can adjust the DVD pot some on the back of the Laser. Turn it about 3 degrees clockwise. Then put it the laser back in. Test the PS2 with no cover on, and use the white round disc from the laser drive cover to clamp a disc onto the spindle. Test DVD and PS2 Games that do not have Blue back.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
Unable to read new games but can read old, used games???
Things like this are usually caused by overlooked manufacturing discrepancies. It may be best to contact Sony with your system's model info, serial number, and date of manufacture. They may be able to help you under warranty. Greg Holiday
Jun 09, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
