How do I Fix my Internet when its Blinking Orange?
I put a Disk in my Computer to Install Windows XP. And when it Installed, I cannot Connect back to the Internet. I have a Wired Connection and the Light Blinks Orange when it's Plugged, but the Computer doesn't give any Notices that anything is Plugged.
I have Tried:
Activating Windows - but it Failed
Doing Wireless - Cannot Connect
Setting up a small home network - Did not work.
How do I get Internet Fixed/Back
  • yellow67r May 11, 2010
    Is there a "Local Area Connection" in your "Network Connections?"
  • 733 Answers
Unplug your MODEM. wait about 15seconds. plug back in. give it a little bit while it looks for the computer's ip address. if that does not help, restart computer. good luck
Posted on Sep 05, 2009
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 18, 2013 | Computers & Internet
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
Can't connect to the internet new hard drive installed, windows XP pro installed when checking hardware : says ethernet controller driver - not installed. tried finding it on the installation CD, get a...
You need the Intel Pro 100 driver for XP. Go to the following web link at Intel: http://www.intel.com/p/en_US/support/highlights/network/pro100ve and download the driver. Copy it to a flash drive. Put the flash drive into your PC that needs the LAN driver and double-click it to install it.
Oct 25, 2010 | Microsoft Windows XP Professional
Lost install disk
You don't even need the installation disk! Just do these easy steps:
Plug in your PC directly to your router. And make sure it is turned on. Also plug in your MODEM into the routers modem port.
On your computer open up Internet Explorer. Then in the address box type in: routerlogin,net
User: admin Pass: password
if password for the password does not work then just leave the box blank. Then just complete the steps.
If this works or if you need help then PLEASE email me:
pmt47@comcast.net
email me wither it works or not!
Feb 23, 2010 | NetGear WNR2000 Wireless Router
Reboot
To Reboot a computer is to turn it off, wait at least 20 seconds, then turn it back on.
A.If you're thinking of Reboot, as to reinstall the Operating System, you use a Restoration Disk, (sometimes listed as Recovery Disk), insert it in your CD/DVD drive, and restart your computer.
(Just press the CTRL, ALT and Delete keys AT THE SAME TIME.
Not shouting. Windows XP and Windows Vista are examples of an Operating System)
B.If you're trying to install an Operating System, from a CD disk that you bought, I suggest you go into BIOS Setup, and in Boot Order, change the first boot device to CDROM. Insert the CD disk in your CD/DVD drive, and restart the computer.
If you buy a Full Installation CD disk, as listed above, you have to change the Boot Order.
For example:
1.You have Windows XP on your computer now. It has problems, and doesn't work correctly. Instead of getting the Restoration Disk from your computer manufacturer, you decided to just buy a genuine copy of Windows XP, and install it. (This is a Full Installation Disk)
The Windows XP you have installed now, will not let the one you bought install over it, by just putting the disk in the drive. Change the first boot device, in Boot Order to CDROM, and it will. The Windows XP you have now, will 'see' the Windows XP you're trying to install, as just the same version. You have to install a better version of Windows, in order for it to write over what is installed.
Such as Windows Vista.
2.You have Windows Vista on your computer, and are not happy with it. You would like to put Windows XP on instead. Windows XP is considered a lesser version, and Vista won't let it write over it.
Go to BIOS Setup, change the first boot device in Boot Order, to CDROM, and it will.
May 10, 2009 | Compaq Presario R3000 Notebook
Download of new XP windows stuck in 16 bit resolution screen
sorry, but learn how to install xp pro. Skip the internet connection. Plug the plug. Install internet AFTER the xp install. let it ride
Jan 25, 2009 | Intel Motherboard
I have problem with the connection of our internet in the computer we have reformatted... the connection is ok...at the back its blinking the green and orange color... but it appears to have page cannot be...
Yup, need to install the drivers. They should all be on you MB install disk. If not, you'll have to get on to a computer that can access the internet and download the drivers. Just google the name and model number of your mainboard plus 'xp driver download', or whatever.
eg: "asus a564-c mainboard xp driver download"
Just as a note, if your LAN is working correctly you should not see an orange light.
Jan 18, 2009 | XFX GeForce 6200TC Graphic Card
Don't have wireless connection on my Toshiba notebook.
Make sure the drivers are installed for your wireless adapter. XP sometimes overlooks adapters during installation. Check the Device Manager for any yellow exclamation points. If you find one, uninstall it and click on the top item (your computer). Right-click the same device and then click Scan for Hardware Changes. You should have your drivers disk ready. The device will likely install, but be unable to find drivers. Point XP to your drivers disk and it should install the drivers for you.
BTW, if you don't have a drivers disk, check your system BIOS for the chipset and google for "<chipset number/name> Windows XP drivers". You should be able to find the drivers and download them from the wired connection before trying the above instructions for reinstalling the wifi drivers.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 17, 2008 | Toshiba Satellite A135-S4527 Notebook
My dvd rw is not detected
Sounds like you need your manufacturer's SATA drivers.
This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
Aug 20, 2008 | Microsoft Windows XP Professional With...
How to remove windows vistra from a acer extensa 5220 and replace with windows xp
HAVE A VALID REGISTRATION KEY for WINDOWS — Microsoft will not let you upgrade your operating system with necessary patches until you VALIDATE your copy of Windows XP - by phone or online. If you try to update or format your system with a shared or borrowed copy of Windows XP, your result may be a crippled or non-working copy of Windows XP on your computer. You’ll need that 20 character number from your Windows Certificate of Authenticity. A certificate of Authenticity looks like the image below:
coa.jpg TO BEGIN:
1 ) Put the installation CD of XP or Windows 2000 into the CD drive and start the computer. Your computer should display “Press a key to start from CD”. You must boot from the CD because you’ll need to format the C: drive partition where Windows is installed on the hard drive.
If your computer is displaying a blue screen with white text, then you can proceed to step #2.
Your computer’s “Boot Order” tells the computer which device to check first when starting the computer. If your computer did not boot from the CD, you’ll need to power on your computer and press either the F2 or F10 or Del key — depending on your computer — to display your computer’s BIOS menu. In the Bios Menu, find the menu that allows you to change the “boot order” and make a change so that the computer will boot from the CD first, instead of the hard drive.
2 ) A blue screen with white text will be displayed. Press F8 to accept the Windows XP Licensing Agreement. The Windows XP Setup program will search for existing Windows installations and “repair or install fresh copy” will appear if a Windows installation currently exists on your machine. Press [Esc] (don’t repair).
3 ) A list of your computer’s disc partitions will be displayed. Press the UP or DOWN arrow keys to choose your main install partition. Note that your system partition must be a primary partition (usually the first partition that appears in the list), not a logical partition.
4 ) Once you have selected your main partition, press ENTER. “You already have a system installed” will be displayed if you already have Windows installed on this partition.
5 ) Press C to continue. From the options displayed, select “Format the partition using the NTFS file system” then press Enter. Windows XP can also run on FAT32, but the NTFS file system is recommended because it is more stable. You will receive a warning about formatting the drive unless the drive is brand-new -Press “F” to confirm you know that you will be formatting the drive. The disc formatting may take a while depending on the capacity of your hard drive.
6 ) The Windows XP install should begin automatically after the formatting is complete. If not, restart the computer with the Windows XP CD in the drive and follow the instructions for installing Windows XP. This can take 35 minutes or more depending on the speed of your computer.
7 ) Once Windows XP has been installed, connect the computer to the Internet, start the Internet Explorer browser, and visit http://update.microsoft.com/windowsupdate to download and install the latest security patches and updates for your operating system. This could take up to an hour depending on the age and version of your freshly installed copy of Windows XP. When I did this last week, there were 79 security patches for the version of Windows XP that I installed.
8 ) Install the sound, video, modem, and other drivers that are specific to your computer and your operating system — as mentioned in the very first step. Follow the instructions as provided by your computer manufacturer. You may be told to restart your computer between installing some drivers according to your manufacturer’s directions.
9 ) Restart your computer, then select “Start > Help and Support” Click any update links you see to install the latest patches and drivers from Microsoft and from your computer manufacturer.
That’s it. Good luck!
May 23, 2008 | Acer Aspire 5100-5022 Notebook
Computers & Internet Logo
214 people viewed this question
David Payne
David Payne
