My laptop wont boot up and just resets itself help!!!!!!!!!!!!!
My computor wont start i press safe mode but just restarts itself what is the problem.
Posted on Mar 14, 2010
    Sergeant:
  • 217 Answers
Try this turn off.Restart hold F8 Key. A menu will ask How to start, Chose Safe Mode.
If unit starts you will have limited use to find out what is causing the issue.Go to start click it then chose system restore and chose a date that unit started(you will lose some programs that were installed after that date but not data in files.If you don't want to use system restore you can try to 1.remove a new program that you installed and is causing the problem.2 disconect any new hardware.3.click start and click control panel,system,device manager,hardware and look for anything yellow, expand if you can to see any yellow ! marks thats your problem.Remove uninstall unless you need it.Restart,I have used System Restore many times it will fix your PC.Good Luck
Posted on Sep 05, 2009
I have a msi a6000 laptop and it keeps shutting off itself and wont boot windows when windows stars booting it shuts off and i clean the fan so thats not it can someone tell me what it's hapening
try replacing the thermal grease on your cpu.
the BIOS have a protection that restart or shut down the computer/laptop when the cpu get to hot.
You can also check if the power suply is working in parameters
Dec 06, 2012 | MSI A6000-226US Core 2 Duo T6600 2.2GHz...
Tip
If your laptop wont boot up....
If You laptop wont boot up, try removing the battery and pressing and holding the power button for 30-60 seconds. This SOMETIMES resets the laptop.
Hint: re-insert your battery before you reboot the system.
on Feb 23, 2010 | Computers & Internet
I need to know how to reset it
How to reset a laptop charger? A laptop charger can't be reset, it's just a piece of wire that provides power to the laptop. Just unplug it and it's reset.
If you want to know how to reset the laptop itself, click on Start, goto the > next to Shut Down and click Restart.
If you're looking to reformat it, start up the computer and enter the BIOS. There should be an option which says "Press F1 / F2 / DEL (Etc.) to Enter Setup". Inside the Setup (be very careful what you do in here), you want to set your boot priority to boot from the CD ROM. This is usually under standard options and should say something like 1st Boot Device, 2nd Boot Device, etc.
Save and exit the setup, then pop in your Windows (or System Recovery) disc. When it says "Press any key to boot from the CD", press a key on your keyboard and follow the instructions on-screen to reformation.
Feb 10, 2011 | Dell Inspiron Mini 910 Laptop Charger...
Laptop wont even boot up
Do you have it on a power strip? if so try resitting it,if the battery is at full charge then you have an internal problem in the laptop itself.Bad power board,etc.Hope this helps.
Jul 25, 2010 | Acer Aspire One PC Notebook
HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook: My Hp laptop turned off by itself and wont turn on...
Make sure your Notebook is not overheat if it is then you have to make sure the fan is working and have to work on the NB by placing it on a hard surface and also BIOS update will also help to resolve the issue.
if in case the notebook is not overheating boot to BIOS screen and check if the Notebook turns off by itself in bios if it does then its a hardware issue and you need to contact manufacturer to service the notebook
May 18, 2010 | HP Pavilion dv9000z Notebook
Wont boot up completly, keeps re-booting itself
press F8 before the booting screen appears.there u will find option to start the computer in safe mode
Apr 06, 2010 | Computers & Internet
UNMOUNTABLE______BOOT_____VOLUME ***Stop: 0 X
It could be a problem with the harddrive and memories ,if you enter the DELL bios setup page when the computer starts up does it have an option to test the hard drive if so test it.
Also if you have two memory sticks then try with only one and vice versa.
Try booting with another boot CD like the ultimate boot CD it has some hard drive testing tools too.
Good Luck
Nov 04, 2009 | Compaq Presario 2195US Notebook
My powerbook G4 does not chime!!
I suggest you plug it into AC power, then boot with Command-P-R held down until you hear the unit chime twice, then release it. Hopefully, it will boot after this.
If not, boot with Command-O-F held down; when you reach the command line, type
reset-nvram [return-key]
reset-all [return-key]
If it doesn't boot after that, you have deeper issues if the machine is actually turning itself on and off.
Sep 18, 2009 | Apple PowerBook G4 Mac Notebook
Wont boot passed windows screen and keeps reseting.
Does it get to a windows boot up? I.E. safe mode options etc or not even that far?
Jan 23, 2009 | Toshiba Satellite A55-S106 Notebook
Laptop wont boot
windows cant be bad, seems your laptop is not geting throught POST (power on self test)
I could probably fix or find the reason If I where near you but not much I can say from here.
Id take it to a professional for analysis, simple problem analysis shoudnt cost itself at all. so.
easyer on all of us that way.
Mar 27, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
264 people viewed this question
David Payne
David Payne
