Question about Garden
Need to replace the pull rope on a weedeater PE550 edger. Does any know how to replace this?
4 Suggested Answers
  • 246 Answers
SOURCE: I need a manual for a weedeater pe550 edger.
Hello:
You can Download Manuals After doing a Search Using your Units Model Numbers at this Site Addy; http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
or you can Contact Poulan/Weed Eater Using the Options at this Site Addy; http://www.poulanpro.com/poulanpro/contactUs.do .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 68 Answers
SOURCE: WeedEater Edger PE550 Starter Rope will not recoil
Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
Posted on Aug 30, 2009
adrnlnrush19
  • 3 Answers
SOURCE: weedeater pe550 no spark at plug
Check the coil.
Posted on Sep 05, 2012
Stihl weedeater pull rope won't pull out how do i fix fs75
Check first for pull rope issue by pulling the side cover and inspecting. If not that it may be something more serious like seized piston.
Aug 30, 2014 | Stihl Fs75/fs80r/fs85r Air Filter Housing
My PE550 weedeater edger that won't stay running. I have new carb, new fuel lines, new starter coil. any idea what could be the problem? I am now checking the gas cap, breather is good
check your fuel lines ensure you have them on correctly also check spark plug clean if necessary also when you change out fuel lines and carb it may take quite a few pulls to crank cause the little fuel system has to get primed up!
Aug 09, 2013 | Poulan Pe550 Gas Edger
Weedeater Troybuilt TB65SS : the pull rope is good. But the rope won't engage flywheel
Did you replace the rope? how much rope was used? and was the flywheel and rope clutch alligned properly on installation?
Jun 25, 2012 | Garden
How do you replace the fuel filter on a Weedeater PE 550 lawn edger?
You can find replacement fuel filters at a nearby hardware store. Once you have one, fish out the line from inside the tank and fit new filter onto line and place it all back into the tank. You will probably have to back out the tube a little after re-installation.
May 01, 2012 | Poulan Pe550 Gas Edger
The screws that hold the carburetor vibrated out and are lost. Any idea what size they are ? SAE or metric ?
Here is your part. To see your whole machine, just select Weedeater PE550 and a couple parts diagrams come up. The part number with a photo and the price are here as well. Shipping is stiff, but this is the best I can come up with. The head is TORX 20 it looks like (could be T-15), but the thread style is the important thing. Good luck!
http://www.ereplacementparts.com/carb-screw-p-269854.html
Sep 06, 2011 | Poulan Pe550 Gas Edger
How do I replace the pull rope on the TE 475 weedeater? I went to start it today and pulled on the rope and it all came out.
How do I replace my pull cord on my weed eater TE 475? I have the parts diagram, I need to know where the cord attaches and what the steps are to rewind the pulley and attach the cord.
Oct 19, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Pull rope does not return
Unless the rope has broken, you dont need to replace it. The problem is probably the rewind spring. It is located under the starter pulley (the one the rope is in). The best thing to do is pull the unit apart and see if you can see if maybe there is something holding the rope up. The spring is a little dangerous to replace. If you go for it, be careful....Lee
Sep 03, 2009 | Garden
Aug 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Pullrope broke on weedeater 550 how do i get it apart to fix it
ther eshoul dbe some bolt holding the pullcord/recoil assenbly to the flywheel/motor. you need to locate and find these bolts first. let me know when you have this apart. you have to unwind the rope and pull it completley out, then buy a new pullcord rope(other rope will just fray and break agai) slip it thru the holes tie a knot wind up the spring and carefu;lly place it back on were it came. let me know if you run into any trouble.
Apr 23, 2009 | Poulan Pe550 Gas Edger
Garden Logo
203 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
