PHILIPS MODEL # 42PF7220/37 WHEN PLUGED IN UNIT WILL CLICK SOUNDS LIKE COMING ON THEN SHUT DOWN IF UNPLUGED WILL REPEAT SYMPTON NO PICTURE NO SOUND.
  • danjimmy432 Sep 04, 2009
    THANK YOU BAD CAP
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Usually it is a swollen capacitor or a burnt component on the power supply board. From the model number you have provided it seems that it is around two years old. Youw'll need to look for Capacitor C 0074 on the power supply board. Are you getting any blinking light on the front panel of your Philips TV?
Please revert for further assistance.
Thanks
Rylee
Posted on Sep 04, 2009
I conected my sub wrong and the unit shut down , I reconected my sub and everything seems to work fine , should I send it in for servicing?
If i'm right, the system powers down as a safety precaution. It prevented itself that it will breakdown. It's your choice but I recon you can just enjoy and listen to your favourite music.
Apr 26, 2014 | Harman Kardon AVR 7000
Unpluged the projection tv put in truck and moved it down the road pluged it n and doesnt work
Check first for loose cables...that is a common issue when the tv sets are moved.
Feb 19, 2013 | Philips 60P8341 60" Rear Projection...
Menu keeps popping up
check remote faulty batteries/take them out see if it stops doing it also depress menu button on tv might be stuck
Nov 10, 2009 | Philips 42PF9630A 42 in. Plasma Television
Not cooling proberly. Unpluged unit for 5
return air ducts are frozen and need to be defrosted. unplug unit and with doors open , introduce warm air from a blowdryer for a couple of hours , the ducts that are frozen are behind the rear panel on the rear wall of the freezer
Oct 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
I have a 85hp Yamaha outboard motor. It starts easily, but wont shut off (with the key or kill switch).
sounds like the ground wire in the control box where your key switch is located is broken are disconnected. check the wiring harness plugs if it is unpluged are not pluged tight it will not shut off
Jun 18, 2009 | Light Outboard Motor Boat Bass Fishing...
No picture/ power button flashes twice constantly. 2 flash code?
Sorry, but there is no simple answer to your problem.
Bottom line, it needs to be repaired by a qualified technician.
The blinking is a code for what circuit area of the set called for the shutdown.
No matter what it is, there is nothing more you can do.
www.mcveyelectronics.com
May 03, 2009 | Philips 50P8341 50" Rear Projection...
Frig shut off
my 7yr old roper refrigerator top freezer stopped cooling and freezing but the light was still on with no fans. I dropped the thermostat cover and jumped the thermostat wires,no help . then i removed the wiring harness from the defrost timer and jumped the #1and #4 .She kicked off. I then replaced the defrost timer and it is running fine now
Jul 16, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Will not Turn-on
the deflection/convergence board requires replacing.the set is checking itself and found a problem and went into shut down.
Sep 04, 2007 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
