Question about Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF E50A10
My TV will not power up...the power/stand-by lights is flashing in pulses of three...any ideas?
  • 10,594 Answers
If standby light flash 3 times that means Lamp Cover is open or not fixed properly on its place.
Please make sure lamp cover is fixed securely.
Have you replaced its lamp recently?
Thanks.
Posted on Sep 04, 2009
Testimonial: "Thank you very much for the input. That, indeed, was the case and my TV is now working fine. Thanks again!"
Sony. KDF-E50A10 HDTV stand by light blinking 3 times
The red power light flashes at 3sec intervals indicating that the light and/or the outer panel door are not secured.
Mar 12, 2013 | Televison & Video
I replaced the lamp in my Sony E50A10 and the tv still doesn't power up.The indicator flashes red.Any ideas?
if its the lamp indicator flashing its an issue with the lamp. If the lamp is new I would double check to see if its making contact completely when its slid in often the pins can get bent slightly. If it were the ballast the power indicator would blink 5 times.
Feb 09, 2013 | Sony Wega KDF E50A10 TV
Sony Wega T.V. won't stay on.
Over Voltage Protection 03. Three blinks of standby light denotes this. The fault is with its main power regulator section circuit. If you wish to get more details about these blinking codes, check this link. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 29, 2013 | Sony Wega KDF E50A10 TV
I need help. My Sony 50 inch tv is a 2006. The warranty ran out in June 2010. I heard a pop and then it shut off. Now the green light flashes 25 times and turns to the red lamp light. I can't reference...
Pop sound was broken lamp in tv, replace lamp to solve tv issue.
Please recheck model number as KDF-50EA10 seems invalid/ incorrect model number and nearest match is KDF-E50A10
If model number is KDF-E50A10 then required lamp part number is as follows...
F93087500 ... LAMP BLOCK ASSY XL-2400
and available with Sony Accessories Store for $200
Let me know if you have addition question or tv model number is other than above said (KDF-E50A10).
Thanks.
Mar 10, 2011 | Sony Televison & Video
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Standby lamp keeps on flashing.
Seems its time to replace lamp in your Sony KDF-E50A10
When lamp in TV got weak in result, standby light start blinking and if lamp got broken / dead, you will see lamp light ON.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for TV safety.
Thanks.
Jul 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 Green picture.
For BnrMan213,
I believe your issue with Light engine.(KDf-E50A10) If you have warranty on this unit contact seller.
Good luck
Dals123.
Same unit different problem
Customer replaced Lamp ***'y still unit bliks, there is two reason.
1.if your lamp door not closed properli it will blink.
2.watch for ballast ***"y fires the triger to on the Lamp? if not your old lamp is good repalce Ballast..
Good Luck
Dals123
Jul 31, 2008 | Samsung HCN4226W 42" Rear Projection...
Sony KDF-E50A10 50 in. LCD HDTV Logo
668 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
