Question about Whirlpool Washing Machines
My Whirpool Estate washer will not rinse spin or drain
My Whirlpool estate washer stops as soon as it reaches the rinse cycle and will not go any further than that.I do hear a buzzing sound though,when it reaches the rinse cycle.
  • 612 Answers
The motor turns in one direction to wash and the other to spin. If it will not spin I feel sure it's a bad motor.
Please rate solution
Posted on Sep 05, 2009
My Estate TAWS800JQ washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin. If knob is manually moved from drain cycle to rinse unit will agitate but not drain or...
Possible that the drain pipe is in a height where the water is struggling to lift.
If not id check for a block. I normally find a sock stuck in the drain hose which causes a problem similar to yours
Sep 24, 2017 | Estate TAWS800JQ Top Load Washer
My estate washing machine will not spin out, all of the other cycles work correctly.
Hello
Try to clean the magnetic door switch,some windex and a paper towell.Just do the part on the door or lid and where the lid meets the top of the magnet.Make sure this is not loose and is seated in the machine.
You may need to unplug machine and remove the door switch,take both wires and tie them togther so they make contact.Then try a wash cycle or try the spin cycle.
The door switches in the estate washers fall apart and get corroded and can stop the spin cycle.
If the machine works with the switch taken out then you will need to get a new one from whirlpool.
Mar 25, 2011 | Estate Washing Machines
I have an estate washier & it makes it too the rinse cycle & stops. Any ideas why?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Whirlpool Washing Machines
Estate Washer (top loader) by Whirlpool. Model Number: TAWS800JQ1 Water will not drain from machine after ten minutes through rinse cycle. It just stops (just shuts itself off) What do we do??
Most likely it is your pressure switch. Locate the switch on your machine and look for damage. if you have a multimeter use it to find any electrical issues if there is no reading the pressure switch needs to be replaced.
Jan 29, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool Estate Washer won't drain and won't work
Need a complete model number to help you. Access to the parts varies with different model numbers.
Aug 30, 2009 | Whirlpool Washing Machines
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
434 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
