Re: OLIVIA lcd tv mod.# 537-b11\r\nTV turns off by
Re: OLIVIA lcd tv mod.# 537-b11 TV turns off by itself. Have to unplug it & then plug it back in.
Sometimes tv loses audio.
Sometimes picture freezes, and tv makes a loud noise.
  • jiro Sep 04, 2009
    Tanks for the tip.
  • 3,741 Answers
Its a internal ic or capacitor getting overheated and short problem.due to which tv is turning off automatically.because the ic or capacitor is short so when you ON the tv it works.but when current passes through that faulty component it gets short and tv turns off/ -------- for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv starts and turns off.in this case the circuit board needs to be checked with a multimeter.the faulty and burned out component part should be detected and then should be replaced with the help of soldering iron.to make it proper.to avoid further damage i suggest you that do not ON the tv again and again as it will short some more tiny components and the reparing cost will increase as per that.at present its the normal circuit short problem in the tv get it repaired before using the tv again.
thanks.please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Sep 04, 2009
I need the Manual for the Olevia 537-B11 TV
Try Googling (olevia)(537-B11)(manual) without parens.
May 29, 2017 | Olevia Televison & Video
I can't get my Olevia tv (537-B11) to scan for channels
I don't know this model of TV, however, you may find that you need to use the Source button on the remote to cycle through the available inputs & select digital tuner as the input source before you press the Menu button & go into the setup section.
Jan 05, 2014 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
I have a olevia 537-b12 with only a blue liught
Contact the nearest authorised service center for Olivia.
Jun 05, 2012 | Televison & Video
Switching Olevia TV, Model 537-B11 from satellite to antenna
You must go into the main settings menu and select the correct input source.
Feb 07, 2012 | Televison & Video
Olevia 537-B11 How to I change the tv settings to pick up the antenna signal?
Go to the menu and find the analog or digital settings...
Please choose analog to use your aerial antenna..
thanks for using fixya..
Aug 12, 2011 | Olevia Televison & Video
We were watching TV and the TV just turned itself off. We try turning it back on and we have a black screen for 10 seconds and then the TV turns itself off again. Called Sanyo and they said to unplug it...
Yes,unplug,replug the tv an hour later.The tv should reset itself back to factory setting and work.Not,than the tv power supply board have problems.That the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 07, 2010 | Sanyo 42 in. LCD TV
My 37 inch Olevia that is 3 or 4 years old is stuck on a very loud, so loud I have to turn it off, but I can't access the volume on the remote or on the TV, it is so weird! The remote does work to turn...
When you have strange problem like this, power supply module will be the first thing to check for steady DC. Since this company is no longer around and parts are getting hard to come by, the repair shop will not even try to do component level repair on it due to time consuming process and no schmatic available.
There may be not much you can do.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Olevia+LT37HV+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
I have an Olevia 37" model 537-B11. How do I take it apart and look first for a fuse on the main board to fix the "no signal" message that I get when using the HDMI cable. I know the HDMI cable and cable...
no signal message is not related to fuses..you have to autyo search the channel of your local tv station thrue your remote control goto menu and search channel.
May 20, 2010 | Olevia 227-S11 27 in. LCD TV
Olevia 540-B11 - no power
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jan 03, 2009 | Televison & Video
Code for universal remote
i would like a code for a universal remote control,my tv is an olevia model 537-b11
Nov 07, 2008 | Olevia Televison & Video
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
