Question about DCS FSF-40 Deep Fryer
I have DCS FSF-40N fryer. the piolet doesn't stay on when I release my finger it goes off I tried to change the gas valve from different brand and I only replaced small part where the electrical wire is connected to it with the therm wire the one goes to the piolet and still did not work, I mean the gas comes through and goes on as long as my finger keep pressing on the piolet knob and soon I take my finger off it goes off. I don't think I need new gas valve if I can find the small part the one has spring to it
You must first check to see if your pilot flame is good. If it is too weak, or not impinging properly on the thermopile, it will not stay lit. If the pilot flame is ok, the problem could be that the thermopile is weak. using a millivolt meter, test the voltage across the thermopile while the pilot is lit (you may need someone to hold the button down while you do this). You will also need to disconnect the thermopile's leads from the control while you do this. You should get about 750 millivolts across the thermopile while the flame is on it (let it heat for a while to stabilize). If your reading is too low, your thermopile may be shot and needs to be replaced. That is of course only if your flame is proper. That voltage is needed (or close) to keep the magnet open so it will stay lit when you let the button go.
Posted on Jun 08, 2010
I have a DCS FSF 75L fryer that cycles fine for a while then flame & pilot go out? Why
Bad thermocouple/thermopile?
Getting trash or air in the gas supply line?
Faulty control valve?
Dec 05, 2014 | DCS Kitchen Appliances - Others
Is there a conversion kit to convert a DCS FSF 40 fryer from natural gas to propane
If it is natural gas fired, why not use butane? Save all the bother.
Oct 27, 2014 | Kitchen Appliances - Others
How to convert from gas to propane
Attach propane, light fire, cook.
Apr 22, 2012 | DCS FSF-40 Deep Fryer
I bought a dcs fryer at a restaurant auction. I had it installed in my restaurant, and when I got it going flames were shooting out of the back. I had it looked at, but because there is no serial number...
The difference between Natural Gas Set Up and Propane Gas Set Up on Fryers are as follows:
Natural gas burner orifice has larger bore (#52) than Propane Gas burner orifice (#55 or #56).
Gas Valve's spring kit for natural gas has less tension (thinner) than Propane.
You have to order burner orifice ( the quantity depends on the number of burners your fryer has), pilot orifice and Gas Valve Spring Kit for Propane Gas if your fryer is set for Natural Gas or vice versa.
Regards.
Jun 22, 2011 | DCS Kitchen Appliances - Others
Fryer over heats,hi limit switch was replaced as well as main gas valve.
Limit switch is last-ditch cutoff.
The thermostat that SETS the temp is where you should be looking.
Apr 04, 2010 | DCS FSF-40 Deep Fryer
Where can I purchase the orifices to convert my DCS FSF-40 fryers from propane to natural gas? Or is there another way?
Contact your gas utility. They are usually very helful and may even do the conversion.
Nov 16, 2009 | DCS FSF-40 Deep Fryer
Thermostat Issue DCS Fryer??
This sounds to me like the thermostat is not sensing and is reading a closed circuit all the time. You will probably need to replace the thermostat.
Thanks
Zerko
Aug 01, 2008 | DCS FSF-75 Deep Fryer
Fryer promblems
This is caused by a failing coil on the gas valve. You should replace the gas valve.
May 08, 2008 | DCS FSF-40 Deep Fryer
DCS FSF-40 Deep Fryer Logo
606 people viewed this question
Top DCS Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a DCS Kitchen Appliances - Other Expert? Answer questions, earn points and help others
