Question about Toshiba TDP-T9U Multimedia Projector
No power Have had this unit for 3 year, about 30 to 40 hours on the bulb....Will not power up. No lights unless you try to power it on with the remote. Then the amber light flashes three times and now it has a solid amber light...This has happen before and it finally powered up.
  • cornuto Jun 14, 2008
    Have no power going into the projector. Have changed leads stilll no luck. Havnt used it in a while. It does this occasionally and then powers on.
  • 22 Answers
I HAVE THE EASY FIX!
I had this same problem & almost threw it away!
If you have had it unplugged for a while just plug it in & make sure the yellow power light is on, then leave it plugged in for about an hour or two. Do not try to turn on before at least an hour, then it can easily be turned on. Make sure you reset the lamp timer option. There & you thought it would be difficult & expensive!
Posted on Jan 09, 2009
I have a Infocus in1503. It shuts down after 10 to 30 minutes. When it does shut down there is no lights. In fact the power light goes off as well.
I seemed to have had the exact same problem... I had placed the projector on top of a small book (to raise the unit), however, did not rest the feet of the projection unit on the book and it overheated and turned off, as a result. (The bottom of the unit was making direct contact with the book which caused it to overheat since not any air was passing through between the two)
After letting it cool for a while and powering it up -- it would usually power off completely for about 15 minutes. After a little thinking, I thought it may be the lamp/bulb and waited a couple of years and bought one online that arrived yesterday.
I installed the new lamp/bulb this morning and it did the same thing. It powered down about a half hour later. Bummer.
I reset the machine to factory defaults and checked to see if it had the 1.03 firmware... It did
Then went through the settings in the setup area and turned off the 'prevent pic screen saver'... Reset the 'lamp hours'
I doubled checked the lamp/bulb installation... Turned it back on -- same thing -- it shut off after about 15 minutes or so... Then unplugged the unit and turned it over and took out the 4 or 5 chassis screws and loosened and took off the side panels and blew onto the fans and circuit board areas and gently pounded the sides to shake anything that shouldn't be there loose and put it back together.
i powered it back on and now it's been working for about 2 hours and 16 minutes!
good luck!
Nov 12, 2013 | InFocus IN1503 DLP Projector
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
Timer model#28486
1) Copy following link to help identify same-similar timers with dawn-dusk selectable time Off.
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) Stanley-Westinghouse timers have 1 year limited warranty, but unknown who you contact for warranty service.
Buy Woods, Intermatic, or GE timers instead.
3) Do not exceed watt rating.
Make sure bulbs are operable.
Try different bulb in same timer output to see if outlet has power.
Buy timers at local store for ez return and exchange.
Try on different outlet.
Test outlet for 80% rated voltage.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 15, 2012 | Hardware & Accessories
After long drive 30,40 km when car stops on traffic lights loose power 2010 outlader
is your check engine light on it could be anything from fuel to emissions
Aug 01, 2012 | 2010 Mitsubishi Outlander
Westek SLC6CFL programming instructions
Copy following link for Westek outdoor socket timer instructions:
http://waterheatertimer.org/pdf/Westek-SLC6CFL-timer-instructions.pdf
Jun 27, 2012 | Ace Hardware AMERICAN TACK 3236858...
The unit is programmed to come on at 5:00 p.m. and go off at 11:30 p.m. It was wooking but now the lights won't come on.
Three things can cause lights not to come on:
1) Timer has gone bad.
Try resetting and reprogramming timer. Make sure you have correct mode.
I test timers. 4-6% arrive defective and most quit within a year or two.
Some go bad within a month.
If display does not show, then check battery.
Most timers have internal rechargeable battery that is not replaceable.
When rechargeable battery goes dead, timer is bad.
2) Light bulb burned out or lamp turned OFF.
3) Receptacle has no power. Plug lamp in directly and see if bulb comes on.
To see manual:
Check following link
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
Dec 21, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Oct 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Fan Failure Error
the temp sensor probably wore out when the fan did. just replace the sensor. usually located on the lamp housing or near the fans. looks like a transistor.
Sep 28, 2009 | Eiki LC-XG210 Projector Multimedia...
Toshiba TDP-T9U Multimedia Projector Logo
330 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
