Question about Homelite Curved Shaft Trimmer Bump Feed Replacement Line
How much gap should there be between the ignition module & rotor assembly when reassembling a Homelite UT20006 trimmer?
    President:
  • 986 Answers
The same thickness as a buisness card work great
Posted on Sep 05, 2009
Pull cord on homelite ut20006 trimmer
on the side where the pull cord was remove casing pull the cord through the hole on the casing wind the spring back on the strimmer not to tight but tight enough for the cord to return once pulled. Attach the cord onto the spring this will be obvious there is a little hole the cord goes through then pull a bit of cord through tie a nott then pull the cord back so the nott is tight against the spring ,let the spring spring back the gord shoul wind onto the spring reattach the casing and job done hope this helps
Apr 21, 2012 | Homelite Mighty Lite Lawn Trimmer
Need coil mag air gap for homelite model ut20006 line tremer
You can set the air gap for the coil with a business card used as a thickness guage.
Sep 06, 2011 | Garden
I have a homelite trimlite trimmer model UT20006 can you tell me which way the connecting rod goes by the part number on bottom rod bearing?
Check the piston itself. The piston skirt is "cutaway" on one side to clear the counterweights of the crankshaft. If it is installed the other way, the engine won't rotate completely as the weights will contact the longer skirt of the piston.
Sep 28, 2010 | Homelite Mighty Lite Lawn Trimmer
I'm installing a new ignition module on a bc24w weedeater trimmer--the part has 2 screws holding it on-it is apparently adjustable--what gap setting should I use between it and the magnet (armature &...
I usually use a match book cover between it and the magnet. this way the gap is about right and it will not hang on the magnets. put through both sides at once, then push it in and tighten it up. then take out guage. spark plug gap is .025, the armature gap on most small engines is .010,
Aug 20, 2010 | Vacuums
Homelite trimmer UT20832
The gap on my 18 year old Homelite ST-185 is 0.025. Since they are still using simple and reliable magnetos, yours should be the same.
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite ranger 33cc chainsaw will not start. replaced spark plug, no luck. next thought was to drain fuel & refill with fresh, but fuel isn't old & i doubt if it has water in it. any other...
Did you check for spark when the plug was out? It should be blue and snappy. If not, you need to expose the flywheel assembly by removing the left case cover, then remove the stop switch wire from the ignition module. If now sparks, check the stop switch and connecting wire for grounding. If still no spark, replace the ignition module. Use a thin businees card for a gap gauge--turn the magnets under the module, insert the card into the gaps, then loosen the mounting screws and let the module stick to the magnets. Tighten the screws and rotate the flywheel to remove the card, then turn the flywheel one full rotation and check that the gap doesn't close up at any point. If the original test had good spark, then pour some fuel mix into the plug hole and attempt start--if you get several pops, then check the fuel system. Start with checking the fuel filter which will commonly plug up over time and check the fuel lines for decay or damage. Does the primer button pull fuel into it when pumped several times? Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and trouble shooting. Note carefully the items within the lower chamber as they are critical to proper running. Hope this helps!
Jun 02, 2010 | Homelite ZR10926 16 Chain Saw
Homelite Trimlite String Trimmer. String won't advance on tapping
remove assembly clean with soap and water and toothbrush(make sure when you dissasemble make notes of how to put back together!)Check spring make sure not broke or distorted-oil with silicon oil(walmart sells or auto parts store)reassemble reverse of dissassemble!!! hope this helps you!!!!
Jun 22, 2009 | Homelite Mighty Lite Lawn Trimmer
My homelite trimmer model ut20006 will not run unless it,s on half choke. I think it,s the low speed jet but where is it and how do I get to it thanks
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Home lite String Trimmer Won't Start
be sure your kill switch is set to run positon and the wires from it arent grounding theirself out . Make sure your spark plug is
grnded to metal when you check for spark.(ground to head away from the spark plug hole
You may have a bad ignition module if you still have no spark or the flywheel keyway has sheared for some reason throwing it out of timing.(removal of flywheel is required to see if the keyways are aligned flywheel and crankshaft)
If your flywheel seems tight then you may be ok
not a high failure rate but it has happened.Gap your plug at .030 then.025 see if that makes a difference? keep going to a smaller gap to show you may have a weak module not able to jump a wider gap.
just a couple things to check hope this helps maybe
May 31, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Curved Shaft Trimmer Bump Feed Replacement Line Logo
180 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
