Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
I replaced my lamp on my PT-61LCX65 last year and
I replaced my lamp on my PT-61LCX65 last Dec and now it is having the same problem. The lamp looks fine (not blown) but the TV won't come on and the lamp light is blinking. I checked inside the lamp housing unit and there was a loose piece of metal that looks like a spring in the shape of a w, but I don't see a place to put it back. Any ideas?
Panasonic pt-61lcx65 - replaced lamp and was working fine except for resetting the lamp hour time? Tv worked fine for a month but now the screen is just all blue and its requesting to reset and repalce the lamp again. How do a reset the time and will this fix the problem
Posted on Nov 01, 2009
  • 556 Answers
Depending on how much you watch this set the lamp could be out again, they don't have to look blown to be blown.
Posted on Sep 04, 2009
When you trun on my panasonic PT-61LCX65 tv it makes no sounds the light blinks green. and then red and turns off. what is wrong. i have looked at the buble and it looks fine.
does the TV bring out sound even as the screen display is dark?
How long have you been using this TV and have you ever changed the lamp/bulb? Problem should be from the TV lamp/bulb.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
PT-61LCX65 lamp light flashing. Believe I need to change lamp and reset? Could you tell me how to reset?
Check the owner's manual to be sure. The troubleshooting section should list the meaning of the flashing lights. Typically this is a bad lamp indicator or a lamp life indicator. The replacemetn lamp should include the instructions for replacing the lamp and resetting the lamp life counter.
Dan
Nov 03, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic LCD Lamp Replacement
Here is the manual for your set, the instructions for replacing the lamp are on pages 66-67.
You can download the manual here.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-61LCX65
To reset the lamp timer
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 21, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Reset tv timer pt-61lcx65 after lamp installation
MAKE SURE LAMP DOOR IS COMPLETELY CLOSED,THATS WHY POWER LIGHT FLASHES YELLOW
Jan 10, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Most likely the lamp will correct this issue.
Apr 08, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Please send me the instruction on lamp replacement
sorry I dont have the instructions for panasonic. but it should be straight forward remove the back and the lamp housing should be right there.
Mar 14, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
490 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
