Question about Kitchen Ranges
Hi....I have the F1 message on my stove. - Kitchen Ranges
    Brigadier General:
  • 3,513 Answers
The F1 fault code indicates a problem with the Electronic Range Control (ERC) Board. If the fault cannot be cleared, they recommend replacing the ERC and the touchpad. Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC)
Thank you for contacting Fixya.com
Posted on Sep 04, 2009
I have a frigidare electric stove. The oven got
Hi
Thanks for using FixYa. Error code F1 means a bad Electronic Range control (ERC) and to resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 26, 2010 | Frigidare GLEC30S8C 31 in. Electric...
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
My stove beeps and flashes F1 after having the stove on for a few minutes
Hi - F1 indicates a fault in one or more circuits on control board. No good news here. Boards range from 150-250$ + install. Usually fail during 'self-clean' or as techs call it- 'self-destruct'. Let me know if info is helpful- Thanks- ED
Mar 02, 2010 | Kenmore Kitchen Ranges
What does the f1 message mean?
this is your part, and f1 code is the board. Always visually inspect the bad part though before ordering but this should fix ya.......good luck..
Electronic control:
http://www.repairclinic.com/referral.asp?R=154&P=496226
  • You have either a bad ERC (clock) or a bad touch pad.
    1. Disconnect power to stove
    2. Gain access to the back of the clock (electronic range control or ERC).
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
    4. Make sure everything is clear and will not short out when power is turned back on.
    5. Turn power back on to stove.
    6. Watch for the F1 and listen for the beep.
    7. If you get the F1 and beep, replace the ERC.
    8. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
      NOTE: Some models incorporate the touch pad and the clock as one part.
Nov 15, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Error on display F1 & E1 Stove will not start
HI. This is a safety flip flop error code, caused by damaged circuitry within the electronic control board. This will require you to have the control replaced asap. This will correct the issue.
Part number (for white control) #3196971
Part Number (for black control) #3196970
Oct 19, 2009 | Ovens
F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore Kitchen Ranges
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
F1 message on Maytag range
This is what the code means.
F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC)
Good Luck and Please Rate
Jan 08, 2009 | Kitchen Ranges
F1 error code on comp screen of wall oven
The solution is people to find yourselves a better website-this one is full of problems and no solutions!!!
Jul 25, 2008 | Kitchen Ranges
Kitchen Ranges Logo
20 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
