Question about Acer Aspire One AOD150-1920 Netbook
My netbook has excellent signal with the router...I do not have an ip address
    President:
  • 2,600 Answers
Start button > Run > (search if you have Vista) type in the box "CMD", hit enter...this brings up the DOS command page. type after the flashing curser..."ipconfig /release"
make sure you put a space between the forward slash and the word ipconfig.
now type in "ipconfig /renew"
Now type "ipconfig" hit enter and look at the ip address, the subnet mask and the gateway numbers...
They should look something like this:
IP Address.......................192.168.1.1**
Subnet Mask....................255.255.255.0
Gateway..........................192.168.1.1
The asterisks are standing in for the last two digits of the ip address for your computer.
If these are in the correct sequence, then connection is possible. If you can't connect after that, try contacting your isp server.
Posted on Sep 04, 2009
I have a TP LINK router, it transmit signal properly. the problem is when the 3G USB internet modem is fixed into it, it does not send internet signal so the laptop shows TP Link signal: excellent, but no...
To solve your problem:
go here
http://www.tp-link.com/us/article/?faqid=92
Basically what you have done is plugged it in but did not set up the router on a static or dynamic IP address.
Once you have established the IP address of the router and it is recognized by your ISP device (DSL, Cable, Satellite modem ....etc etc.) then you have to decide which device will be the DNS server and assign IP address to all the wireless devices that connect to it.
Lots of things can be wrong. You need to follow the steps on the set up link i gave you properly and in the correct order
Oct 23, 2013 | Computers & Internet
I HAVE AN EXCELLENT SIGNAL FROM MY ROUTER BUT THIS NETBOOK WILL NOT CONNECT. I HAVE BEEN WORKING ON IT SINCE CHRISTMAS AND DONT KNOW WHAT TO DO....I HAVE TWO VERY DISAPPOINTED LITTLE GIRLS HERE
If your trying to get on the internet with a wireless connection.and running WINDOWS,(many problems with LINUX) .and I am assuming you DO have a wireless router all set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
try resetting the router (disconnect the power to it for a few minutes) next --be sure the wifi switch is enabled on the netbook---next---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
follow this is a link to a troubleshooting flow-chart
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If you continue to have problem..indicate at what point in the flowchart it is getting stuck
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Dec 31, 2010 | Sylvania G-Netbook
My router is not gettting connected with laptop. Its hsowing lmited connectivity problem eventhough the signal strength is excellent.
Sometimes the router does not issue an IP address to the laptop and you get this error message.
Right click on the wireless icon on the Task Bar and click on Repair. The router will issue a new IP address to your laptop and you will be able to get Internet connection.
Dec 09, 2010 | D-Link Wireless N 150 Home Router 4Port...
I have an acer netbook. The wireless connection is excellent but i can't surf the internet. If I try to repair it tells me that cannot renew IP address
1. Please check your D - Link router's DHCP is enable or not.
2. Please check your computer's IP address on automatic.
3. Please check your D - Link router on mixed mode.
Mar 13, 2010 | D-Link AirPlus DI-524 Wireless Router
I have excellent signal strenght but wont allow
try to restart it with a pin, if that doesnt work log into your systems ip address and address the issue there
Mar 01, 2010 | D-Link DIR-625 (790069292637) Wireless...
Cannot get Toshiba Netbook connected to wireless network
ok. try this:
open a computer on your network that connects to the network. start -> run -> type cmd and click enter.
then type ipconfig /all
then open your laptop.. go to local area connection and click properties.
click internet protocol on the list and then properites.
click on "use the following ip"
and on the three text boxes below type the same settings as the ones that appear on the pc that you did ipconfig /all. the only differnt will be the ip address. if the pc is 192.168.0.105 you should put 192.168.0.106 or something else.
do the same with dns server.
click ok to close all the opened windows and check the new ip of the laptop
Jan 25, 2010 | Toshiba Mini NB205-N313/P Netbook
2 computers, my main is hooked up to modem and dsl with router, it works fine but laptop get excellent signal but wont go online
Try changing your ip address settings to:
IP 192.168.15.99
gateway to 192.168.1.1
dns to 4.2.2.1
Worked for me
Apr 08, 2009 | Linksys (WRT54GC) Router
Unable to get IP address on SMC2804WBRP-G
You need to setup security on the laptop/access point. Apparently it has been setup in the router.
Jan 25, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
Router won't log into it's IP address online
Is your desktop getting an ip address from the router?
You said that you reset the router, do you mean turning it on and off or pressing the reset button?
Aug 03, 2008 | NetGear WGT624 Wireless Router
RG54SE II
In your wireless router,U want to configure the ip adress of internet,may R u static ip R dynamic ip address,
1. Statis ip customer means, configure the static ip address in your wireless router,
2. Dynamic ip customer means, configure the ip address of the ADSl modem ip.
May 20, 2008 | MSI Wireless-G RG54G3 Router
Acer Aspire One AOD150-1920 Netbook Logo
269 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
