Question about Canon PIXMA MP150 All-In-One InkJet Printer
Error message "Waste Ink Absorber Almost Full" Question: How do I remove and clean or change. Thanks - a satisfied customer - I love the MP 150 Bob Hall sorry - forgot e-mail address e-mail: hd2wheeler@gmail.com
  • 1 more comment
  • hd2wheeler Sep 04, 2009
    I followed your solution to the letter. I even disconected it from the computer the second time and then unplugged it for 10 minutes and plugged it in and did it again. The little window continues to flash "E" then "8" but will not reset.
    Your comments.
    Thanks
    Bob
    rylee_smith
    Rank: Guru
    Rating: 86.99% , 659 votes
    Rylee - correction did work - I had to print out a document. Once I went to print the document, got the error message waste ink absober almost full, hit the color start button to override the error message it printed and apparently then reset. Works fine now.
    Thanks - You get my vote.......
    Bob
    finally reset.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Open the cover, move the cartridges to the centre, and then press the pad of absorbent paper towel onto the waste ink pads. You can locate the waste ink pads to the right of the cartridges. This will absorb a lot of ink in the pads and that will remove the warning after you reset the printer waste ink tank counter. You can reset your Canon MP 150 by following this procedure—
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button 4 times for waste ink counter reset.
5) Turn off the printer.( it must be turn off) then turn it on again.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 04, 2009
  • Rylee Smith
    Rylee Smith Sep 04, 2009
    Hi
    Thanks for using FixYa. Error E8 is the waste ink error only. Please check thi procedure for reset--
    Service mode operation procedures:
    1) With the printer powered off but connected to a power source, press the Power button while pressing and holding 1) With the printer powered off but connected to a power source, press the Power button while pressing and holding.the Stop/ Reset button. The Stop / Reset button.
    2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button. 2) When the Power LED is lit, press the Stop / Reset button two times while pressing and holding the Power button.
    3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into aservice mode. service mode. (Waiting for menu selection) (Waiting for menu selection)
    4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the 4) When the LED lights in green, press the Stop / Reset button the specified number of time (s) according to thefunction listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in function listed in the table below. (Each time the Stop / Reset button is pressed, the LED lights alternately inorange and green, starting with orange.) orange and green, starting with orange.)
    The number of the Reset button pressing LED Function Remarks
    4 times Green Waste ink counter reset See waste ink counter reset procedures below. 4 times Green Waste ink counter reset See waste ink counter reset procedures below.
    Thanks
    Rylee
    Thanks
    Rylee
  • Rylee Smith
    Hi
    4 times Green Waste ink counter reset See waste ink counter reset procedures below. 4 times Green Waste ink counter reset See waste ink counter reset procedures below. Reset
    except for the followings: Reset except for the followings:
    - USB serial number - USB serial number
    - Destination setting - Destination setting
    - Waste ink counter - Waste ink counter
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
Ink absorber full
There are two possible reasons for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an MP Tool
Mp Tools are utilities designed to clear errors that will appear in an MP160 printer. Download this MP Tools here.
while the printer is on Run this software
1. Click Reset Main (main) to reset the waste ink counter and
2.
Click Reset Platen button (E27).
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber is full cannot print
Mp Tools are utilities designed to clear errors that will appear in an MP150 printer. Download this MP Tools here.
2.
Happy printing.
Aug 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber (sponge part)
2.
Happy printing.
My printer shows E 2 7. how can i fix it?
i believe on this model the error code means that the ink tank is full...
http://www.mediafire.com/?s2pa54m5z2wqwru
this is a link to my hosting site where you can download the software reset tool for a the MP models...
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Additional information error codes for the MP models...
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Aug 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Tank for used ink is full - how do I change it?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E27 Error Reset
E27 Waste ink absorber full or platen waste ink absorber full.
Download the MPTool from this site. It is a resetter utlity for the MP series printers.
http://pcprinter.blogspot.com/2008/02/mptool-multi-resetter-for-canon-mp.html
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Waste ink pad full error message
plz check the website http://www.fixyourownprinter.com/forums/inkjet/50418#1
Aug 04, 2008 | Canon PIXMA MP170 All-In-One InkJet...
Waste ink absorber on canon iP 1600
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Apr 01, 2008 | Office Equipment & Supplies
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
