Question about Canon PIXMA iP4200 InkJet Photo Printer
How do you change a printhead on a canon ip4200
  • 736 Answers
Raise the lock lever (at the top of the print head .. lift out the print head .. remove the covers from the new head and place where the old one came out .. it will be at a slight tilt .. then close the lock lever (pull down until it latches) .. replace the ink carts in the new head as soon as possible before they dry out .. do a print head cleaning .. then do a nozzle check ..
usually the old print head just has clogged nozzles .. there is a utility under "devies and printers" .. "ip4200" .. "adjust print options".. that will allow you to clean and test the heads ..
the new print head is about $58 .. so its expensive to do unless you are sure yours is bad .. the print heads usually stay healthy if you do the following
1. print something .. color and black at least every week or so ..
2. dont let ink run out completely
3. never unplug the printer without first turning it off .. wait until the heads are parked ..
4. in case of a power failure while the printer is being used .. then power it back up as soon as possible to park the heads (that seals them so they dont dry out)
a complete user manual is available from canon if you need one ..
Posted on Sep 04, 2009
Error number 6A00 for Canon Pixma IP4200 Blinking Power and resume light.
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Pixma ip4200 willl not print Cyan
I think the problm lies between the ink tank and the printhead. When this passage runs dry, sometimes it takes time for the ink to fill this passage again. Try printing again after a day or two.
Jul 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
ERROR SIGNAL CODE 5 FLASHES
Error also refers to the EEPROM for the printhead. I would reset the EEPROM and see if that helps.
Printer servcie manual here and it will show you how to do it:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
Hope that helps
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma Ip4200 Ink Smudges
1. Do you use refilled or genuine Canon cartridges?
2. Anyway, try to clean the printheads, because they seam to leak.
3. Verify if the cartridges are correct alignet (in maintenance software you have soewhere an "align cartridges" function
Feb 11, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 - not printing in colours
hi i am a Canon certified tech for this machine.the orignal problem you had most likely was not your printhead but since you washed it most likely it is ruined. the problem most likely is the purge unit. the purge unit is the unit to the far right of the machine. this unit cleans and purges ink from the ink tanks to the printhead. to do this it uses 2 pads one for black and one for color. these pads can be flushed with water to soften up any ink. i would also replace the printhead which can be ordered by calling 1-800-OK-CANON or by going to their website. one other tip, refilled ink cartridges cause more clogging of printheads and purge unit then OEM ink. this is because the ink is thicker then the OEM ink. hope this helps to clairify.
Jan 02, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon ip4200 colour magenta
the colors transfer to the printhead by gravity. the felt on the inktank must make intimate contact with the stainless steel filter in the printhead. I have a pixma ip 6000D that I had to replace the printhead inside of two years three times. the bubblejet circuitry in the printhead got burned out. New heads cost from $55 to over a hundred.
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Red colour prints brown
Just replace the non genuine inks with proper Canon ones and then do about 4 full cleans, that should fix it. If not you will have to replace the printhead, which is usually caused by using non genuine ink. Good luck
May 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
910 people viewed this question
old marine
old marine
