Question about Amana ABL2222FES Stainless Steel Bottom Freezer Refrigerator
My Amana (bottom freezer) starts knocking every so often.
Brand new refrigerator. The knock started the week it was delivered four months ago. Three separate repair visits to my home have failed to solve it. Soft knock, knock, knock. It almost sounds like cavitation. The refrigerator cools just fine. But this intermitant noise is getting to be pain!
  • 3,267 Answers
It could be unequal tightening of the mounting of the compressor. Also check the belt for uneven thickmess...........sodeep
Posted on Sep 04, 2009
The water and ice started tasting very bad with a sulfur chemical taste a few months after the water filter was replaced. What should I do?
Did you recently have a water main break in your area about the time the bad taste started or any plumbing repairs in the house?? Could be the filter is contaminated. Try another filter and go from there. If problem is gone it was the filter. If still there---possible problem with refrigerator water system and tubing.
Mar 15, 2015 | Whirlpool ED5LHAXW Side by Side...
Information display window reads tire maintance and I just bought four new tires less than three months ago?
Ensure your Tire Pressure is correct and RESET your Tire Pressure in the FUSE BOX. They neglected to reset your Pressure
or
They Broke your one of your Sensors (Those Basttarts).. If that happened, bring it back to Firestone
Apr 15, 2013 | 2007 Nissan Altima 3.5 Sedan
Have brand new battery on car and it looks corroding
Pur hot water over the conections, and then spray it whit a WD-40 or something on the terminals; try with a battery charge.
Jan 05, 2013 | 2001 Toyota RAV4
Amana fridge stopped working for 2 days
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 03, 2012 | Amana AFF2534FE Bottom Freezer French...
New compressor started knocking 1 month after installation
could be a bad unit from day 1,motor loose internally,or it can be moisture in the sealed system
May 12, 2012 | Amana ABL2222FES Stainless Steel Bottom...
I have bought the Karizma ZMR on July 2010 abotut 9 months ago. But I started to ride it just about three months ago,initially my dad used it. A week before while I use to ride it I used to get...
Hi, Me_sumitok take it bake to where it was serviced and I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Chains---RATTLE
5. Clutches---CHATTER
6. Cylinders---PING
7. Fronk Forks---Plunk
8. Gears---WHINE
9. Head Gasket---HISS
10. Hydraulic Lifters---TAP
11. Pistons---SLAP
12. Rear Shocks---SQUEAK
13. Shifting Trans---CLUNK
14. Solid Lifters---TICK
15. Starters---CLICK
16. Connecting Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.xbhp.com/talkies/motorcycle-ownership-experiences/10257-hero-honda-karizma-zmr-584.html
Hero Honda Karizma Zmr
Hero Karizma ZMR
http://www.partsfish.com/page/oem-parts-for-honda
Hero Honda Karizma Zmr Owners manual delay
Apr 14, 2017 | 2006 Hero Honda Karizma
Hi I have an LG- LFX23961SW The water hose that goes from water valve to ice maker keeps freezing up so no water goes to ice maker. We first thought the problem was the water valve, but discovered the...
Water is delivered to the ice maker mold bymeans of a "tube-within-a-tube" design. A conduit system consisting of three separate pieces(liner fitting, conduit, back panel fitting) isfoamed into place in the cabinet.This conduit provides a pathway from thefreezer liner to the back panel. The majority ofthis system is routed above the refrigerator linerto prevent the water tubing from freezing. Thetubing that delivers the water is routed throughthe conduit, and is secured by snapping into place at the freezer liner fitting.
And also check freezer temp and defrost system is working.I hope repairman would replace the insulation of tube by taking door as you said. Thanks.
Jan 29, 2011 | LG Refrigerators
Knocking noise in refrigerator section
This will be a loose mount on the electric motor (tighten)
May 05, 2010 | Amana ABB1927DE Bottom Freezer...
Refrigerator knocking noise
If it seems to be coming from underneath the unit it could be the compressor. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That's usually mounts inside the compressor. Usually when the compressor cuts off. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Any other noise would be from a fan. One in the freezer behind the back panel and one under the unit where the compressor is.
Dec 29, 2009 | GE Profile Stainless Bottom-Freezer...
Amana ABL2222FES Stainless Steel Bottom Freezer Refrigerator Logo
611 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
