Where is the tube?
You have a drain hole in the back bottom of the freezer with a tube attached to it which goes down to the drain pan under the unit.
You have water line tubes on the back going to the ice maker and to reservior in fridge and on to the freezer door up to the dispenser.
There is a fill tube in the freezer where the water comes in to fill up the ice mold.
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
