Question about Siemens Dishwashers
Hello, Our 4 year old Siemens dishwasher is not starting. The standby light shows its getting power but no start. It is off warranty. thanks, Barry Lehr
  • 1 more comment
  • bdlehr Sep 04, 2009
    H- I tried purhing harder; it didn't do anything...
    Pushing on the door does nothing. Our Siemens Dishwasher still will not start..
    Thanks,
    Barry Lehr
    How much do you think it might run?
    Barry
    President:
  • 1,564 Answers
This gennerally happens because the door closed sensor is not sending the correct info back to the main board. Try pushing a little harder on the latch when you close the door, you might just get lucky! Thanks, Dana
Posted on Sep 04, 2009
  • Dana Newcombe
    Dana Newcombe Sep 04, 2009
    Than you've probably have to replace that switch. This is your cheapest way out to start diagnosing the machine without having the proper equipment. It is similar to changing a lightbulb before buying a new lamp.
  • Dana Newcombe
    I'll need the model and serial numbers for that info.
DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
May 09, 2012 | Candy Dishwashers
No power
Hello
Plug the Siemens dishwasher into a working electrical outlet if nothing on the dishwasher is operating. Check the household circuit breaker or fuse and reset or replace as needed.
Push the door closed fully if the dishwasher has power but isn't starting. The unit will not operate if the door is open.
Sep 11, 2011 | Siemens 24 in. SL34A006UC Built-in...
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Washer will not start. "Clean"
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 20, 2011 | Dishwashers
Hello ... We have a GE Quiet Power 3 Dishwasher -- only two years old. Dishwasher won't start ...and we are getting an 1h code. What is a 1h code? The manual does not provide any code...
Try unplugging the unit for several minutes if that does not fix the issue you will need to replace the main control board to fix the issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Dishwashers
KitchenAid kudpo1flss dishwashe wont do anything. If you push the buttons to start wash nothing lights up and it will not start. thanks for any help you can provide.
I have this identical model and have had this identical problem twice now, as the dishwasher is 6 years old. I contacted my appliance parts store and they sold me a thermal fuse. Changed it out, less than $25, worked like a charm. Tech ability needed is 4/10 to disassemble door, rewire fuse, reassemble.
Dec 26, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
Siemens buillt in dishwasher
do you pre rinse the dishes before puting in dw?if so stop and dont use as much detergant
Jun 03, 2010 | Siemens 24 in. SE64A630GB Built-In...
Emmerson HDTV f32
The failure with this LCD might be due to a failing power supply or backlight inverter board. Since your TV is less then a year old, I would suggest to call the manufacturer to get it fix under warranty.
Good Luck.
Jan 17, 2009 | Televison & Video
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Dishwashers Logo
41 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
