Question about Soltek (EQ3705M) Barebone
Power supply ENP-2725D
Guys my Qbic sl-b8e-f intel865G + ich5
no power on boot no lights at all tried another power lead and back burning from power supply can this be replaced ? any idear's where
  • Wwallace Jan 10, 2008
    im stunned !! power supply dead !!!!!!!!!!!!!!! memory or cmos battery has nothing to do with a dead power supply
Have a Soltek SL-B78-F2.02 Model 3702m Qbic system and I need to update the Bios and the Nvidia Nforce2 all-in-1 driver, as well as fix the sound driver. I have searched the web for two days and all I get is offers for driver agents. Does anyone have a real fix or can tell me where I can get a good download? Anyhelp would be appreciated, skinose2@hotmail.com
Posted on Oct 15, 2008
Again Daniel. clean Memory and batterie works only 5 times. now y have the same situation like bevore.when y push the Powerbutton only flashs the light in the Button.eni idea waht we can do? Greetings Daniel
Posted on Jan 10, 2008
Hi my anme is Daniel and y found the solution on this Website. Cleaning the Memory and the Batterie, it was helpfull. thanks
Posted on Jan 08, 2008
  • 3 Answers
Remove RAM and cleaning it safetly the reinstall it.if it is not working then remove CMOS battery and clean that one and reinstall it .after that send a message to me.
Posted on Dec 11, 2007
Dear Guru my power supply of my computer with model enp-2120d doesnt work no power output so please gave me some idea or schematic diagram,thank you.
Do not try to fix this power supply. Better to replace with new or good used. I see many on ebay from 13.50 to 25.00. Also google that model for other options. Most likely fuse on the power supply has failed but if you bypass the fuse, with jumper wire or another fuse, will blow again. Probably capacitors. Good luck
Aug 28, 2011 | Enhance Technology ENP-2120D (ENP2120D)...
My computer did not start when i tryied to turn it on, so i pushed the red butten to the side at my power suply and tryied again ther was a loud bang from the powersuply and ther was smoke comming out from...
The only thing to do at this point is to replace the Power Supply with a KNOWN to be good, compatible unit, and see if the rest of the computer hardware components are okay.
Going by your information stated that the Power Supply is an Enhance ENP-2224B SMPS, (Switched-Mode Power Supply), it is a special shape.
If it wasn't for the Slim Micro-ATX computer case you have, you could use an easy to obtain ATX form factor Power Supply.
From a quick search though it looks like a replacement unit is affordable,
http://www.censuspc.com/Enhance-ENP-2224B-2G-240W-SATA-TFX12V-P4-Power-Supply-for-Slim-microATX-Desktop-Case-Serial-ATA-Ready-bulk-pack-SKU-ENP-2224B-2G-pr-3033.html
There is simply no way to tell if the motherboard, and/or Processor, and/or Ram Memory, and/or Harddrive, etc., is okay without having power.
Unless you transfer the components on the motherboard to another working motherboard.
[NOTE*
If your Power Supply has a rocker switch on the back that lets you use 120 volts, or 220 volts, make SURE it is set to the right voltage.
USA?
120 Volts
Europe?
220 Volts
Australia?
220 Volts
Japan?
100 Volts ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 26, 2011 | Enhance Technology ENP-2224B, Enhance 240W...
No power at all, np lights come on and well nothing!
No power and power LED does not light up, this indicates either the mains power is off or you have a faulty power lead. Test the mains socket and the mains power lead.
If these are OK then the fault most likely a faulty switch mode power supply. Remove the switch mode power supply and get it tested at your friendly computer repair shop OR borrow a power supply and insert it into your PC to see if it now boots up.
If it boots up the replace the power supply with a new switch mode power supply with the same total wattage or higher wattage.
Apr 01, 2011 | Packard Bell iMedia SL 9553 (P660401806)...
No power. Fan does not turn. Changed power cable but still no power
Then your power supply is dead. You can purchase a new power supply relatively cheap. Give newegg.com a try.
Feb 01, 2011 | Enhance Technology ENP-2120H, Enhance 200W...
The enp-2320 will not turn on, any thing i can do? is there a fuse i can replace?
Welcome I want you to help does not exist DC voltage reading was 1.5 disappear
Sep 16, 2010 | Enhance Technology ENP-2320, Enhance 200W...
Where to purchase a new 250w ENP-3125 power supply unit in the uk
Go to any computer-store, carrying your old power-supply with you,
tagging which of the connectors that you use, and which of the connectors that you do NOT use. The sales-representative can then find a "generic" power-supply with the same height/width/depth, and with the necessary connectors,
and with the necessary power-output (volts & amperes).
Jul 17, 2010 | Biostar ENP-3125 (250w psu) 250-Watt Power...
Motherboard suppord CPU
google the mother board and then read the book for the board. it should list the compatable cpu's then you can log on to www.geeks.com and search for the cpu you want that will work with it.
Jun 27, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Soltek SL-B8E-F Mainboard
I need a manual for this motherboard, the Soltek SL-B8E-F
Sep 02, 2007 | Intel Motherboard
Soltek (EQ3705M) Barebone Logo
471 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
Paul Bade
Iqbal Husain
Iqbal Husain
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
