Question about Sanyo Refrigerators
Supplementary wire tubing running parallel to the evaporator coil has burst in four places and broken the internal resituve wiring
  • 358 Answers
That's the defrost heater ,and if is broken ,it has to be replaced.
Posted on Sep 05, 2009
How do i wire alpine swr1243d subwoofer
There are a couple different ways you can wire up this speaker as it is a DVC speaker. Duel Voice coil, it has two + post and two - post. A dual 4-ohm voice coil subwoofer with its coils wired in parallel presents a 2-ohm load to your amplifier. Since an amplifier produces more wattage at a lower impedance, the parallel connection ensures you'll get the most output from your amp.
Series wiring lets you configure multiple woofers to one amplifier at an acceptable impedance. Wire both coils in series for an 8-ohm impedance, and then wire two 8-ohm subs together in parallel for 4-ohm total impedance.
You can wire each voice coil to a separate channel of your amplifier, if you prefer not to bridge your amp. Independent wiring is a nice option if you're wiring two DVC subs to a 4-channel amplifier - one voice coil per channel
Depending on what you are hooking it up to i.e. a mono amp or a bridged four channel amp. I can tell you post to wire exactly if I know how you want to hook it up and what ur hooking it up to.
Sep 15, 2014 | Car Audio & Video
Do you bridge a 850.4 four channel amp when it is 2 ohm stable and ur subs are wired up as series/ parallel and there 2 ohm dual voice coil speakers
If you wire 2 ohm dvc speaker parallel that would give you a 1 ohm load. If your amp is only 2 ohm stable that would not work. You would have to wire the speaker in series giving you a 4 ohm load. Then you can bridge the 4 channels into 2 with each speaker running at 4 ohms.
If you want to run a 2 ohm load use all 4 channels on amp and speakers. No need to bridge.
For 2 ohm DVC:
Parallel = connect both + and - together. = 1 ohm
Series = connect + from 1 channel to - from the other channel. = 4 ohm.
Jul 06, 2014 | Car Audio & Video
Black wire that goes from top to bottom on back of refrigerator is frosting up..
You sure it is not a tube? If it is the tube going up TO freezer from the high pressure side of the compressor then you are low on gas - evaporation is taking place there instead of the evaporator coil in freezer compartment.. If it is the tube returning to the compressor from the evaporator you have too much refrigerant - but this is only the case if you recently had unit serviced and maybe too much refrigerant was introduced into the system.
Mar 31, 2014 | Admiral 26 cu. ft. Side-By-Side...
How to replace picture tube
Hello
Replacing 27" picture tube must be done very carefully as it will have bulky and care must be taken not to break it. You have to disassemble the internal circuit boards from the TV for that. Make sure to mark every pull out sockets whcih are connected to the circuit board as a rough drawing on a paper, otherwise you may be confused later. You just open the back cover of the Tv, some Samsung models may have locks also with them with fixing screws. Keep the set opened, do a close whatch tho its connections, and board positions. Most of them are pushed in to slots and can be pulled out easely.
Colour picture tubes are integrated with its deflection yoke, as company fittings. We can't replace them alone with an accuracy as they did, which needs sophisticated equipments. normally wires going to the deflection yoke are connected to the board with a socket. A four wire connection is common. Out of them, two is for Horizontal Deflection, and the others two are for vertical deflection. The deflection yoke fitted at the neck of the picture tube has internal windings for both.
Pull out and detach the deflection yoke connection from the board first. be carefull becuse, it may be a little tight to detach, and keep your hands so away from the neck or the present picture tube. If it breaks accidently, may be dangerous. Next look into more connections to be detached. There will ba a two wire connection that comes from the coil fitted around the picture tube, which is called degaussing coil. Pull out the neck board gently and causiously. Pull out all boards out and you have done the half job.
Unscrew the four mounting screws that fixes the picture tybe to front cabin. Gently pull it out from it, you must havav an another to assist you, since it is heavy. Place it somewhere on a blanket upside down.
Seperate the degaussing coil of this picture tube, make notice its connection position, and fit it to the new picture tube, where it will have this coil. It only have deflection coil, and purity magenets on its neck, permanantly fixed. Place this picture tube to the fromt cabin, after placing a smooth folded blanket or so to prevent it from any scratch, screw it to a gentle tight positon inorder to keep it there fixed. Never overtight that screws, as it mat brake the glass envelope of the tube.
Desolder the wire from the old picture tube, note the positions of them. It is best to cut it out from there very close to the soldering point, so that a little bit of wire with insulation be there. It will help you when reconecting wires to the new picture tube, as they are colour coded. Replace all the boards and wires disconnected later according the markings we have done. That is all. Ok
Nov 01, 2010 | Samsung TSL2793HF 27" TV
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do i hook up kicker solo baric in the box
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
To get the most power what is the best way to connect paraelle or
run them straight and dont use the cross over. One speak on right channel and the other on other channel. Then turn up amp settings 7/8 the way up and control the rest from your dvd/cd player. I recommend some monster cable which is very thick. Ground the amp directly to trunk bolts but make sure to scrape the paint off or the connection will be bad. You can also use a cap which will send battery pulses to amp much quicker.
Nov 19, 2009 | Lanzar VIBE286 Car Audio Amplifier
How do i wire two audio pipe dvc woofers to this amp. do i use all four terminals on da amp. jl audio 500.1
Hello smoovek2008,
The JL Audio 500/1 outputs 500 watts RMS into a load from 1.5 to 4 ohms. Whether your subs have 2 ohm or 4 ohm voice coils, they should be wired in series and the subs paralleled to the amp. The final load to the amp will be either 2 ohms or 4 ohms, both of which the amp can handle. If you parallel the voice coils and then parallel the subs, the final impedance will be either 0.5 ohm or 1 ohm, both too low for the amp.
You can wire each sub to a separate set of terminals or both to the same set. The terminals are connected internally. It doesn't matter which of the +'s or -'s you use.
Hope this helps.
Sep 25, 2009 | Jl Audio 500/1 Car Audio Amplifier
Help wiring kicker cvr12's
Hello pr7met7me,
Assuming that the "old sony box" has 2 chambers with at least 1 cu/ft of internal volume each, there should be no problem running the Kickers. The CVR's are dual voice coils and come in either 2 ohm or 4 ohm versions. The coils are wired together either in parallel or in series and then wired to the box terminals.
You did not specify what make and model of amp that you intend to use. The amp will dictate how the sub voice coils are wired. You do not want to go below the minimum load that your amp is capable of supporting. If your subs are the 2 ohm version, you wire the dvc's in parallel and then parallel both subs to the amp, your final load to the amp will be 0.5 ohm and there are not many amps stable at that low of an impedance.
The terminals with the white dots are for the first voice coil. The terminals with solid-red and solid-black markings are for the 2nd voice coil. In a parallel setup, you would wire the white-dot positive and the solid-red terminals to the box internal positive and the white dot negative and solid-black to the box internal negative. In a series setup, you would run a jumper from the white dot negative to the solid-red and then connect the remaining terminals to the box terminals.
Hope this helps.
Apr 11, 2009 | Kicker CVR12 Car Subwoofer
Refrigerators Logo
47 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Steve
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
