Question about Brother MFC 210C All-In-One InkJet Printer
Tried each solution, for new problem
NOW the printer just says "1". It still won't turn off or print, but responds to menu set ups buttons abit- insisting I'm not registered when I push the upwards arrow. Any ideas?
  • winzeler Dec 08, 2007
    but now it says"unable to clean,see troubleshooting and routine maintenance chapter in user's guide". I tried again the menu/black start/ 4x up arrow combination, but there's no change this time. So....
  • 832 Answers
Plz disconnect machine from power and replug in again. If you still receive the 1 when "normally" powering up you might have deleted some important info within the
eeprom. This cant be fixed anymore.
Unfurtunately this error is not discribed within the service manual and I never had a defedtive mfc with that error/info.
Posted on Dec 08, 2007
  • Mix-it-up
    Mix-it-up Dec 09, 2007
    do press menu start bk 4x arrow up. After that press 8 then zero. machine will switch. press start bk several times until PURG XXXX (where X is a No.) appears on lcd. press 2 then 7 then 8 then 3 and purge will get a reset to 0000.
    YOU HAVE TO CHANGE THE WAISTINKTANK TO A NEW ONE because it seems that it is filled up with waist ink! You can buy one at a service partner
    which can found on the brother homepage!
    DO NOT ONLY RESET BUT INSTALL A NEW INK ABSORBER! Otherwise you will damage machine more seriously!
Our printer is flashing Tractor1 tear. We are not able to print nor can we get this to quit flashing. I have tried turning it off and back on still having the same issue. Help?
The "Tractor 1 Tear" message is not a error as such, this is an information message showing the printer is set to the front tractor feed (tractor 1) if you press the button directly under "Tear" the printer should move the paper to the tear possition.
If the pritner is not printing I would recomend checking the following;
  1. Ensure the printer is set to "ONLINE" press the button you should see ONLINE TRACTOR 1 TEAR on the display
  2. Ensure the printer is loaded with paper, press the button under "Tear" the printer should move the paper forward if it is loaded into Tractor 1.
  3. If you are not using Tractor 1, ensure you select the paper path you are using within the menu and move the paper selection lever.
  4. Observer the LCD display for any errors that may be seen when print jobs are sent.
  5. Try printing a menu print on the printer this will identify if the printer will print, the menu can be printed in the following way.
    -Power the printer ON holding down the button, keep the setup button held down whilst the printer initializes.
    -When the printer has finished initializing ensure the printer is OFFLINE
    -Press and release the button to enter the MENU
    -Press the button under "MENU" on the LCD display
    -Press the button under "PRINT" on the LCD display
    The printer should print a menu settings page, if this prints OK the most likely causes for the problem are;
  1. The computer system is not sending jobs to the printer (check the correct printer is selected on the computer system)
  2. Connectivity problem (check cabling, IP Addresses etc)
  3. The wrong printer driver is being used
Mar 04, 2011 | Tally T2240/24 Matrix Printer
HP P3015 suddenly printing very slowly - about a page a minute
If you unplug the cable from the printer to the PC and print the MENU MAP, does it print slow or at normal speed?
If it prints slow, try following the directions below.
If it prints at normal speed, try removing the printer from the print queue and reinstalling it. Also, download the PCL5 drivers and reinstall it.
Good Luck.
Print a MENU MAP and a CONFIG page.
You will need this info to put the settings back in the printer.
1. Turn the device off.
2. Turn the device on. When the memory count begins, press and hold the CHECK MARK button. Continue holding
down this button until all three device control-panel lights flash once and then remain on. This
might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the ^ button
until COLD RESET is highlighted.
4. Press CHECK MARK . The device performs a cold reset and then continues its power-on sequence.
5. Check all I/O settings and reset any customer-set device configuration values.
COLD RESET sets ALL control panel menu items, including network settings back to factory defaults.
This is where the MENU MAP and CONFIG info come into play.
Feb 09, 2011 | HP P3015 Laser Printer
I have a Brother MFC-210. It was working well. When I moved and hooked it back up. It was printing some pages fine and then it started printing double like 3d. Started with a few words. Now the whole page...
Check the alignment. Press the key for Ink or Ink Management on the Control Panel. Select Test Print (the up/down arrows) and hit Menu/Set or Set. Select Alignment and press Menu/Set or Set. Next hit Mono (Black) Start. Look at the Alignment Sheet that prints out. Press 1 if the number 5 sample matches line 0 for both 600 and 1200 DPI samples. Press 2 and then the number for the line that matches that matches the 0 sample.
Then press Stop/Exit. Repeat this for color printing by using the Color button.
You should also check the Print Quality. (Very similar menu choices - just choose Print Quality after choosing Test Print but you only need to hit the Color button to print the test sheet.) This will initiate a cleaning cycle for any poor quality ink test pattern. You will need to respond Yes or No for the print quality and each ink (if you answered No). If you do the cleaning 5 times with problems, replace the cartridges in question.
Finally try cleaning the printhead (Press Ink or Ink Management and then 1 for cleaning) If 5 repeats do not help, contact Brother support, the print head may need to be replaced. (Unfortunately, this isn't the only reason for the problem. Once you put in a print head, it isn't returnable. It could be that the entire printer is ready for recycling.)
I hope this helps.
Jun 24, 2010 | Brother HL-2040 Laser Printer
We are setting up new TallyGenicom LA800. However, printout has dot or period in between each characters printed. Hence, a single row info is printed on two rows. What seems to be the problem?
It would be strange for the printer to print dot between each printed character without this coming from the system.
As a check the first thing I would recomend doing would be to print a self test print on the printer, you can do this easiest by printing a menu print.
To print a menu print put the pritner OFFLINE
Press SETUP
Press the button under MENU
Press the button under PRINT.
The printer should print out its configuration page, if this has dots between each character then this defiantly means you have printer problems.
You can try defaulting the pritner back to factory settings, this is down by holding down the four buttons (1, 2, 3 & 4) under the LCD display whilst powerind the printer on.
If the menu prints OK, then there is some sort of other strange system or communication problem.
If the pritner is connected via serial, check the serial settings on the pritner also chack the pin configuration of the connector used to print to the printer.
Try printing from another system or application to identify what might be causing the problem for example an application or driver problem, perhaps try printing from a PC directly to the pritner to check the interface on the printer is OK.
Check the emulation setting on the pritner ensure this is correct.
Aug 02, 2009 | Epson Stylus Photo 2100 InkJet Printer
Printer will stop printing and you have to turn it off to make it restart? What can I do to repair the problem?
It looks like a communication issue. It seems that the printer is quiting to communicate with the computer intermittently.
If the printer is on network, you may want to reset the printer IP address and reinstall the printer driver to test.
Cold reset unlocks menus that have been previously locked and sets all control panel menu items (including EIO settings) back to the factory defaults. However, it does not clear the values in the
SERVICE
NOTE: Before performing a cold reset, print a menu map and a configuration page
2. Turn the device on. When the memory count begins, press and hold the check button. Continue holding down the check button until all three device control-panel lights flash once and then remain on. This might take up to 10 seconds
3. After the message SELECT LANGUAGE appears on the display, press the arrow up and arrow down buttons until COLD RESET is highlighted.
4. Press the check button. The device performs a cold reset and then continues its power-on sequence.
Print a configuration page from the Printer INformation Menu after restarting the printer. The IP address would ideally be a different one if your network is a DHCP network. If not, you will have to manually configure the IP address on the printer. You may do that by accessing the Configure Menu on the PRinter control panel.
Try configureing the printer driver to the new IP address. It should solve the issue.
If that doesnt work, you may want to download a new driver from the website and install it.
Jun 30, 2009 | HP LaserJet P3005 Printer
Every other word either red or blue
Please follow these steps and then try to print :
For winows system :
1. Click Start, Settings, Printers (Windows XP: Control Panel, Printers and Faxes).
2. Right click on the Lexmark printer icon and select Properties.
3. Select the Printer Settings tab (Windows XP: click on the Printing Preferences button) and click on the Change button.
4. Close the I Want To menu and select Print Color images in Black and White.
5. Click OK to confirm the new settings.
For mac system
# Load plain paper into the printer. Open the Page Setup screen and select the required settings.
# Then open the Print screen and customize the image printing settings as follows:
1.
2. From the software application, select File, Print. From the Printer pop-up menu, choose your printer model and then continue.
3. From the pop-up menu in the upper left corner, choose Color Options.
4. From the Document Color pop-up menu, choose Black Only.
5. Click Print.
Mar 20, 2009 | Canon BubbleJet i560 InkJet Printer
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
Can't print to my Canon
Lett click on the START tab in the lower LH corner of your WINDOWS home screen. Left click on CONTROL PANEL, then left click on PRINTERS. Find the icon of your printer on the PRINTERS page and right click it. On the drop-down menu, make sure PAUSE PRINTING does not have a check mark next to it. Next, lleft click on PROPERTIES. . On the PROPERTIES screen, left click on PRINT TEST PAGE BUTTON. If it does not print, note any errors and try to correct them. You can also delete the driver and try loading a new driver from www.usa.canon.com.Left click on DOWNLOADS. Then, just follow the onscreen instructions for downloading and setting up the new driver, and your printer should then work.
Jul 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
HP LaserJet 2420dn prints twice
You may have checked this already, but make sure your printer driver is not set up to print two copies per print job if it is then that's the easiest place to change settings. Or you can print out your printer's menu by doing the following: To print a menu map 1. Press (SELECT button) to open the menus. 2. Use (UP button) or (DOWN button) to scroll to INFORMATION, and then press (SELECT button). 3. Use (UP button) or (DOWN button) to scroll to PRINT MENU MAP, and then press (SELECT button) Look for anything that says "copies" and usually that will let you know what is set on the printer. To change a control-panel setting 1. Press MENU to open the menus. 2. Use (UP button) or (DOWN button) to scroll to the menu that you want, and then press (SELECT button). 3. Some menus might have several submenus. Use (UP button) or (DOWN button) to scroll to the submenu item that you want, and then press (SELECT button). 4. Use (UP button) or (DOWN button) to scroll to the setting, and then press (SELECT button). Some settings change rapidly if (UP button) or (DOWN button) is held down. An asterisk (*) appears next to the selection on the display, indicating that it is now the default. 5. Press MENU to exit the menu Good Luck.
Aug 24, 2007 | HP LaserJet 2420dn Printer
Brother MFC 210C All-In-One InkJet Printer Logo
50 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
