Question about Car Audio & Video
Having problems with the installation of the brutus 2008d amp in my truck. how many channels is it? how do i connect the subs? do i connect the rca cables from the radio to the input or output.
  • 733 Answers
The rca cables from your stereo go to the "input" part of the amp. Now, if there are four speaker connections in your amp, then it's a 2 channel. If you have eight speaker connections then you have a four channel amp. Note, some amps can be briged to provide more power to the speakers. On a two way amp(2 speakers), the connections can be briged to only one speker providing more power, usually whatever the amp power rating is, say a 500watt amp will put all 500 watts to that speaker. The same goes for a four way amp(4speakers), can be bridged to two speakers(250watts per speaker). Hope this helps.
Posted on Sep 05, 2009
I have a 10.2 Orion Hcca subwoofer 4 ohm and wanted to know if I can put each coil to each channel its a Brutus 1200 watt 2 channel amp model 1210d is it safe for my woofer and how much rms wattage I'm...
You would need to know what power your amplifier supplies at 4 ohms. In reality, you would be better off bridging the amplifer and wiring your sub in parallel to a 2 ohm load. This would allow you to pull the most power out of the amplifier. It would be safe to do a voice coil to each channel on a 2 channel amp. However, if you happen to have a 4 voice coil sub and attempted to put two 2 channel amps to it, you would have to make sure your amps are leveled. No easy feat. The variance you could have with that could damage the voice coils. But luckily, that's not your case.
Sep 09, 2011 | Orion HCCA 10.2 Car Subwoofer
Brutus amp output problem
must be a bad amp..have you tried bridging them maybe youre channels are out it happens even if its brand new...factory deffects
Feb 21, 2010 | Hifonics Brutus BX 1605D Car Audio...
Illuminating the sub
i would assume hooking it to the remote and ground of the amp
Apr 24, 2009 | Hifonics Brutus BX12D4 Car Subwoofer
Hook up my 2 sub and my 2 amp
wire the subs at 2 ohm each. red to red and black to black and then to the amp. if thay are a dual 4 ohm sub. dual 2 ohms will need to be wired red to black on one coil and the other conected to the amp.
Apr 09, 2009 | Danby DDR601 Dehumidifier
High Pitch Whine from Amp (not speaker)
make sure your rca andpower/remote wires are ran on seperate side of your car.it maybe recieving some kind of interference from the alternator. try buying higher shielded wiring too
Apr 20, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Hifonics bxi 1206d
make sure you have a 40 amp fuse in it
im going to try to describe this to you
to bridge a amp this is for 2 ch AMP
I 2 2 I
I 2 2 I
I I 22
I I 22
I I 22
I I 22
#1 SPEAKER #2 SPEAKER
WIRE WIRE
ONE GOES ON THE POSIVE OF ONE SIDE AND THEN THE NEGATIVE OF THE OTHER
HOPE THIS MAKES SINCE
PLEASE LEAVE MY RATING
Feb 11, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Problem with hifonics 1505 class d mono
The positives are connected together and the negatives are connected together. The two pairs of terminals are for convenience. You'd connect one speaker to a pair of positive/negative terminals and you'd connect the other speaker to the remaining pair of positive/negative terminals.
You need to confirm that you have a good signal feeding the amp. If you have another amp in the vehicle, swap the RCA cables between the amps to see if it makes a difference.
You also need to confirm that the speaker are working properly and that there are no broken connections in the wires. If you disconnect the speaker wires from the amp and touch the wires across a D-cell battery (for a fraction of a second), the speaker should pop. if it doesn't, check the wiring to determine why.
Dec 27, 2007 | Hifonics Brutus BX 1505D Car Audio...
Problem!
you have a foulty amp i wtake it bk and change it
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
