Question about Video Game Consoles & Games
VTECH V Smile TV learning system part...
I'm working on a V Smile (orange and purple) that has one broken pin on the Card Edge Connector Slot. I can't get any info out of VTECH. I would love to know where I can buy a replacement card slot for that unit, it is otherwise in good condition. Is there any help for it?
  • Jim Cooper Nov 08, 2008
    I am looking at foxconn and 3M connectors to find a replacement. It looks like the same pin spacing as an ISA connector. The key is not the usual bit that slides in between the connections. Instead they have removed one set of connections and inserted a key. I think the board is actually thinner than a PC card. I need to measure. The ISA slot has more space at either end of the card which would cause the cartridges to line up improperly.
    Problem Solver:
  • 12 Answers
Toys.pricegrabber.com is where you can buy the replacement card slot for v smile. Ebay is also good if your ok with used cards.
Posted on Dec 08, 2007
Our v tech v smile system won't stay in the on position
Remove all Smartridges, controllers, adapter or batteries.
Examine the Smartridge slot for loose objects, Blow into it to
remove dust or debris.
Pull back the plastic sleeve on the Smartridge and clean both sides
of the metal contact with alcohol and a q-tip.
Insert the Smartridge into the Smartridge slot and remove quickly
twice without turning on the V.Smile unit.
See if that will help.
Jun 29, 2010 | Vtech V.Smile TV Learning System
I plugged in my vsmile and there is power but there is nothing coming on the tv screen
Pull back the plastic sleeve on the Smartridge and clean both sides of the metal contact with alcohol and a q-tip.
Insert the Smartridge into the Smartridge slot and remove quickly wice without turning on the V.Smile unit.
Then try to see if that fixes the problem.
Jun 26, 2010 | Vtech V.Smile TV Learning System
Not playing on the screen. green light is lit,
of the metal contact with alcohol and a cotton swab.
May 15, 2010 | Vtech V.Smile TV Learning System
Vsmile shuts down when cartridge inserted
Insert the Smartridge into the Smartridge slot and remove quickly twice without turning on the V.Smile unit.
This should fix the problem.
Mar 28, 2010 | Vtech V.Smile TV Learning System
My childs vsmile switched on but then switched itselfs off,changed the batteries & it worked for a few seconds then switched off again & will not switch on.
Try this: press and hold the ON button for 45+ seconds WITHOUT the batteries. Then put new batteries in. It worked for me. I bought a second unit at the thrift store and thought it was broken until I tried that. Works just fine now.
Jan 06, 2010 | Vtech V.Smile TV Learning System
Pin bent on V Smile Controller
Always make sure there is no power before you start working on it. You can try to carefully bend them back into place with a tiny screw driver (jewlers screw driver) or pick. You can look at where the connector goes into to see where it should be. If its bent too far or too fast it will probably break.
Aug 17, 2009 | Vtech V.Smile TV Learning System
Infant learning system lost manual
http://www.vtechkids.com/support_manuals.cfm?browseletter=V
May 06, 2009 | Vtech V.Smile TV Learning System
Various Smartridges stopped working
You may need to inspect the inside of the cartridge slot for dust/dirt - swab it with a tiny amount of cleaning alcohol and see if you get better results.
Jan 03, 2009 | Vtech V.Smile TV Learning System
I Buy the Vtech V.Smile TV Learning System and it donot work
Make sure the power cord is plugged in and that the red/white/yellow cables are plugged properly into the TV. Also, as you plug the red/white/yellow cables into the TV, make sure you turn the TV to the right channel - it is different for every TV. For instance, the red/white/yellow on the front of my Sony is labelled Video 2 - yours might be labelled FRONT, AUX, or something else.
Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Nov 24, 2008 | Vtech V.Smile TV Learning System
Video Game Consoles & Games Logo
104 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
