Question about Motorola Mobility PEBL U6 Cellular Phone
Not ringing My Motorola Pebl just stopped ringing...it vibrates and the phone beeps when I press on buttons, etc. The sound works, however, none of the ringtones make any noise! It just happened this morning and I hadn`t changed any settings or anything that would affect volume...
My iPhone incoming calls ring but do not vibrate, but all other notifications vibrate correctly.
Strange. I would try resetting your iPhone. Hold down the home and power buttons until it powers off. It should start up automatically but if not just press the power button. This has worked for me in the past when my iPhone has acted strangely.
Don't worry about a reset or hard reboot. You won't lose any data or settings.
Aug 06, 2012 | Apple iPhone 3GS Black (16 GB)
Cell cant ring
ur ringtone is in the vibrating mode i guess.... better change ur ringtone to loud or ascending in ur PROFILE.........settings--->profile
Oct 05, 2009 | Motorola Mobility PEBL U6 Cellular Phone
My motorola pebl phone will not ring
Hii
can u plz chk and tell me if ur profile is set into vibrate mode? and regarding keys, u can set the key tone volume to zero.
if ur a new user here is wht u hav to do
> MENU > RING STYLES > Change it to LOUD or VIBRATE and RING
Regards
Hope it helps u
Sep 11, 2009 | Motorola Cell Phones
Phone won't ring or vibrate and keys click and beep when pressed
I brought my phone in to my service provider and they removed the battery and sim card (because I was unable to turn of my phone with the power button) and rebooted the phone. It's all good now.
Mar 19, 2009 | Nokia 2600
Motorola pebl u6 speaker problem
you need to take the phone and have the speaker replaced but if it is still new it is under warranty still so you should take it back and have it changed or replaced.
Sep 01, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Motorla PEBL not ringing
Okay Ive had this phone.
Do any other sounds on there work?
such as music in the sounds area?
Or Sounds in games?
If NOT I would think that the internal speaker has been damged by the water.I would try and get it repaired by motorola,or under warrenty.
If these sounds do work,and it is only just that there is no sound when you get msgs or calls,check your phone is set on a loud style,rather than silent or vibrate.Normally you can change this by going to Settings and icoming call alerts if im remebering right.
Or I Think you you can change it by the side buttons.
Hope Ive Helped You Out.
Good Luck With It.
Sophie x
Feb 14, 2008 | Cell Phones
Speaker problem?
cay78 - have the phone firmware reflash you can do that online or take it to a mobile service center and have that done, that would correct the issues.
Jan 14, 2008 | Motorola Mobility PEBL U6 Cellular Phone
MotoPebl does not ring!
mine did the same thing. i figured out that my songs were turned down (i dont know how this happened in the first place cuz it worked for the first couple of times then stopped ringing but...)
go to your menu, then multimedia, click sounds, then click whichever ringtone is yours, when it comes up use the volume button on the right of your phone to turn it up.
this worked for me, my phone is up and running now :)
hope this helps!!
Dec 29, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Pebl won't vibrate
Its the vibrating mechanism that went bad. Seen it a million times. Go get that fixed at your local cellphone repair shop. If you need the part or want us to do it for you check my profile.
Nov 28, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Will not ring or vibrate.
Go to settings... personalize....ring type... pick loud ...scroll down to edit then go in and change from silent to the ringer setting you choose
Jun 26, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Motorola Mobility PEBL U6 Cellular Phone Logo
116 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
