How to remove thermocouple from water heater - Washing Machines
  • 15,935 Answers
Remove the pilot access door.
you will see the thermocouple mount right by the pilot light.
turn the gas off before replacing it.
Sometimes you can scuff the tip with fine grit sandpaper and adjust to the flame tip instead of replacing it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
How to replace thermocouple in 42v50-50f
Copy following link:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Rheem 42V50-50 is ordinary atmospheric-vent gas water heater with mechanical (non-electronic) gas control valve, which says that unit has ordinary thermocouple, and not thermopile.
Buy generic thermocouple from local hardware.
To replace the thermocouple you need to remove entire burner assembly from water heater, and have replacement Burner access door gasket on hand. 1-800-268-6966
Combustion door held in place with tamper-proof screws
Since the water heater problem may be more complicated than just the thermocouple, and water heater flame arresor screen may need to be cleaned, and burner parts cleaned, door gasket replaced, and gas pressure checked, and piezo electrode checked, it might be best to have qualified service technician do the work for $300.
Jul 28, 2012 | Rheem Water Heaters
How to remove and clean thermocouple in Rheem gas heater
There should be no reason to clean the thermocouple, but to remove it:
1. Turn off the gas to the appliance
2. Remove the 4 tubes/connections at the bottom of the gas valve
3. Remove the 4 t-20 screws holding on the burner door
4. Pull the burner chamber out
Apr 10, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Rheem PG50T9A gas hot water heater. We had hot water this morning. When I came home the pilot light was out and won't stay lit. Any ideas?
Hopefully just the thermocouple. The thermocouple is the small rod right next to the pilot light. The flame on the pilot heats up the thermocouple and keeps the gas valve on. You can replace it yourself. The thermocouple will be connect by a small nut on the underneath side of the valve, and you will have to pull the thermocouple out of the pilot assembly. Not an expensive part, you can get it at any hardware store. Hope this helps you .
Apr 21, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I WOULD LIKE TO REPLACE MY THERMO CUPPLING
In simplest terms, a thermocouple is a temperature sensor. Normally inexpensive, a thermocouple is standard on hot water tanks. If your thermocouple breaks or you feel it is not working properly, consider replacing it b?p=y23r90wnbq7oglkvtnbuhgyhrktxauzqpeoaddsf&t=18g7grtjm%2fx%3d1290445898%2fe%3d2143440281%2fr%3dacont%2fk%3d5%2fv%3d8.1%2fw%3d0%2fy%3dyahoo%2ff%3d2680761980%2fh%3dcg49imfjb250iibzzxj2zulkpsjzmjnsotb3tkjxn09nbgtwve5ivuhnewhys1r4yvv6cxbfb0fezfngiibzaxrlswq9ijq4mtmwnteiihrtdg1wpsixmjkwndq1odk4ota5njiwiia-%2fq%3d-1%2fs%3d1%2fj%3d6f060d4c&u=13gohjn6b%2fn%3df8a.bkwnpkw-%2fc%3d715481.14405591.14260180.13829426%2fd%3dlrec%2fb%3d6235626%2fv%3d1 lg.php?category_id=6&content_type=article&content_type_id=584031&key_page=1721642411054458764&site_id=1&bannerid=10089&campaignid=2945&zoneid=2&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f584031%2fhow_to_change_a_thermocouple_on_your.html%3fcontent_type_id%3d584031&cb=ebe6534afeavw.php?zoneid=2&cb=1721642411054458764&source=&n=a14de4a9&slice=-1060-&dma=-0-&cty=-us-&content_type=article&content_type_id=584031&category_id=6&key_ad=1045292919&site_id=1&ad_pos=2&key_page=1721642411054458764&ac_url=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f584031%2fhow_to_change_a_thermocouple_on_your.html rather than installing a new gas hot water heater.
Begin this project by shutting off the gas control knob on your hot water heater. Once you are sure that the gas is off, you should use a wrench to remove the nut that attaches the thermocouple to the gas hot water tank. This nut should appear to be securing a piece of copper tubing or other type of tubing. With the nut removed, you should also pull down on the tubing, dislodging it from the thermocouple.
Sometimes there is another nut that attaches the end of the thermocouple to the pilot bracket, if this is the case you should unscrew this nut as well. You can slide it down the tubing and keep it there until you need to replace it.
With the nuts that were holding the unit in place removed, you should be able to slide the old thermocouple out of the brackets that hold it to the hot water heater. You should then take it to a hardware or home improvement store and find a suitable replacement. Then follow these steps to install the new part and fix the hot water heater.
To change the thermocouple, you should press the end of the thermocouple into the pilot bracket as far as you can. If you had to remove a second nut to remove the old thermocouple, now is the time to replace that nut securely.
With the thermocouple in place, you should connect the lead to the control unit. Use the nut you removed in the beginning steps to secure the lead. You should then tighten it at least a quarter turn with a wench to make sure the lead is securely attached to the control unit of the gas hot water heater.
Now that the new thermocouple is installed on your gas hot water heater, turn on the gas shut off valve that you turned off earlier. You should be able to relight the pilot and the functionality of your gas hot water heater should be restored.
Dec 06, 2010 | Heating & Cooling
I have old rheem ruud hot water tank. it's down for 4 day's, i would like to get it started, but the thing i would like to find out is can i get it going by lighting it up by using lighter or not. The...
Yes you can light it with a BBQ type lighter (long enough).
If it lights and stays lit then you need to change the thermocouple (looks like a little pipe off gas valve)
In simplest terms, a thermocouple is a temperature sensor. Normally inexpensive, a thermocouple is standard on hot water tanks. If your thermocouple breaks or you feel it is not working properly, consider replacing it b?p=y23r90wnbq7oglkvtnbuhgyhrktxauzqpeoaddsf&t=18g7grtjm%2fx%3d1290445898%2fe%3d2143440281%2fr%3dacont%2fk%3d5%2fv%3d8.1%2fw%3d0%2fy%3dyahoo%2ff%3d2680761980%2fh%3dcg49imfjb250iibzzxj2zulkpsjzmjnsotb3tkjxn09nbgtwve5ivuhnewhys1r4yvv6cxbfb0fezfngiibzaxrlswq9ijq4mtmwnteiihrtdg1wpsixmjkwndq1odk4ota5njiwiia-%2fq%3d-1%2fs%3d1%2fj%3d6f060d4c&u=13gohjn6b%2fn%3df8a.bkwnpkw-%2fc%3d715481.14405591.14260180.13829426%2fd%3dlrec%2fb%3d6235626%2fv%3d1 lg.php?category_id=6&content_type=article&content_type_id=584031&key_page=1721642411054458764&site_id=1&bannerid=10089&campaignid=2945&zoneid=2&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f584031%2fhow_to_change_a_thermocouple_on_your.html%3fcontent_type_id%3d584031&cb=ebe6534afe avw.php?zoneid=2&cb=1721642411054458764&source=&n=a14de4a9&slice=-1060-&dma=-0-&cty=-us-&content_type=article&content_type_id=584031&category_id=6&key_ad=1045292919&site_id=1&ad_pos=2&key_page=1721642411054458764&ac_url=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f584031%2fhow_to_change_a_thermocouple_on_your.html rather than installing a new gas hot water heater.
Nov 22, 2010 | Heating & Cooling
Senseo thermocouple junction -
once you locate and remove existing thermocouple reverse procedure best of luck
Oct 15, 2009 | Rheem 24" Water Heater Thermocouple Kit
The pilot light on my gas water heater continually goes out. I can re-light the pilot and get it going. The gas burners goes on runs for awhile. I'm assuming when that when the temp hits the desired temp...
getimage_new.asp?id=599586&imagetype=2&noimagetype=2&colorimagesize=2
The pilot assembly should look similar to the pic above. Depending on where you live, you may be required to hire a certified plumber to replace the parts. If not you can do it your self. Keep in mind if it's not staying lit you also need to check the thermostat and the thermocoupler before replacing the pilot assembly. There is a good chance it is just the thermocoupler going out. It is one of the first things to check when troubleshooting a pilot light problem with a gas water heater. A thermocouple determines if the pilot light is lit. If it's not lit, the gas valve fails. If that's the problem, replace the thermocouple.
  1. Shut off the gas valve on the water heater and the gas valve on the line near the heater. Remove outer and inner doors, and loosen the pilot and supply tubes and the thermocouple connections to remove the burner assembly.
  2. Step 2 Loosen the screw holding the thermocouple to the bracket. Remove old thermocouple. Bring it with you to the store to ensure you are buying the proper replacement.
  3. Step 3 Install the new thermocouple. Position the thermocouple so that the pilot flame heats 1/2 inch of the tip.
  4. Step 4 Reinstall burner assembly in the water heater. Tighten burner supply tube, pilot tube and thermocouple connections. Tighten thermocouple no more than a quarter turn more than hand-tight.
  5. Step 5 Turn on both gas valves. Check supply tube and pilot tube for leaks with soapy water. If soap bubbles, tighten connections to fix leak. Ignite the pilot light, and make sure the thermocouple tip is heating up. Replace inner and outer doors.
Jul 09, 2009 | Northern Tool Water Heaters
Whirlpool water heater thermocouple
Nope, turn off all gas to the heater. Remove the enclosure containing the burner. Disconnect both the gas line and the thermocouple line from the gas valve and pull out the whole burner assembly. Take a pair of needle nose plyers and remove the thermocouple from the pilot assembly. Install the new one and reverse the removal procedures to put it all back together. Check to make sure there is no gas leaks and this is important, The nut to turn off the burner tube from the gas valve is reverse threads. Righty to turn off, Leftie to tighten.
Nov 20, 2007 | Heating & Cooling
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
