Question about Sharp AR-5316 Advanced Digital Imager Copier
When installing a toner/developer cartridge in a sharp Z-57 copier is there a reset procedure to follow?
  • CruiserGB May 11, 2010
    I'm not familiar with a Z-57 sharp copier. Could you please confirm the model number from the unit.
    Scholar:
  • 118 Answers
If there is the instructions on when and how to perform a reset will be included with the toner/developer cartridge.
Posted on Sep 04, 2009
Sharp MX-M232D Copier call for service F2-40
Problem with your toner supply .... you're not getting enough toner mixed into your developer tank. Sometimes the cartridge will empty out without the machine giving warning, or the CRUM counter chip on the back of the cartridge wil zap out or wind down to zero. Try replacing your toner cartridge, if that doesn't clear the code your developer mix is out of balance and may need to be changed and reset.
Aug 19, 2013 | Sharp MX-M232D Multifunction Copier
I' ve a problem with copier ar 5516. i need information about using of developer. where i must to put the developer? the toner AR-021FT IS COMPATIBLE WITH THIS COPIER?
yes ar021FT toner compatible for your 5516. when replacing the developer:1) pull out the toner cartridge,2) pull out developing unit with 1 screw (blue),3) in developing unit remove 2 screws (blue) to open its top cover,4) drain d unit and replesnish with new developer. do procedure 4 to 1 to return. Good luck.
May 22, 2011 | Sharp AR-5320 Black and White Copier
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
How i can install developer in sharp copier AR-5316
The steps to take are
  1. Open the toner door.
  2. Remove the toner cartridge.
  3. Unscrew and pull out the compartment housing the toner cartridge.
  4. View to see three screws on the compartment undo them.
  5. Next you see an enclosure with spiral, rigth there you pour in your developer. Then couple.
I hope it worked.
Thanks
Engr. Kachi.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
My sharp ar5316e show f2 04 solve this
clear the memory of the machine, change the destination of the toner or fixe in a new toner crum or also known as toner sensor
Jul 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
Blank copies on an ar208s sharp copier
Inside this machine has 3 sections. Toner cartridge, developing unit and drum unit. First pull out the toner cartridge then you will see a blue anodized screw, loosen this screw then pull this section ( developing unit ), if there's already toner inside the chamber, clean it and pour the all the developer into the chamber then put back the developing section, tighten the blue screw and install the toner cartridge.
May 12, 2009 | Sharp AR208s copier AR208s All-In-One...
Error F 2 (Blinking mode) appears in Display of Sharp AR5316,
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
Feb 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
How do I change the developer in a Sharp sf2022 copy machine?
- If you have Manual please read carefully and follow the instruction.
- If you know how to change the Toner Cartridge? the same procedure also the developer.
- Developer located at the Toner Cartridge side
Sep 19, 2008 | Sharp Office Equipment & Supplies
Add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Dec 30, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
133 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
