Home | Samsung | RM255LASH Side by Side Refrigerator | Samsung model rm255 dis...
Samsung RM255LASH Side by Side Refrigerator
Problem for Samsung RM255LASH Side by Side Refrigerator
Samsung model rm255 display not working after power outage
By yesskippy on Sep 04, 2009
I had a power outage, and the display started flashing between "89" and "98" continuously. I opened a closed the doors a few times and it started to function normally again. Now after another power outage, it is doing the same thing. I have tried unplugging it for 5 minutes, hit every combo of buttons, but no change. None of the buttons on the control panel work, although I do have ice and water supply. Is there a way to reset this or is there a fried componant somewhere...
Solution #1
posted on Sep 04, 2009
Not Rated)
charlymonty
Rank: Wiz
Rating: 82%, 185 votes
Press the power freeze and power cool buttons at the same time for 8 seconds and more and check out.its the reset procedure. --------------- also press and hold the top left and top right buttons (which are for the temp in each section) for about 5 seconds to reset. ------------------------ If the flashing bar is the top of the right side 8 in the refrigerator side display this means the sensor is bad in the ice maker.. as per you mentioned between 89 and 88 this means ice maker sensor is gone bad. ------ if the sensor looks ok then check the frig fan and the thermistor near the top light and clean out all the ice collected near the fan and in that area. ---------- this two options will help. thanks.please do rate the solution.thank you for using fixya.keep updated.
Popular Solutions for Samsung RM255LASH Side by Side
Questions and Unsolved Problems for Samsung RM255LASH Side by Side
Do you recommend Samsung RM255LASH Side by Side Refrigerator?
Answer
Answer
I change my water filter, and when I try to reset the change filter indicator light on the front... (More)
Answer
Lost power to the house but when power came back on, the control panel flashes with 98 on the left... (More)
Answer
ice not dispensing and the frozen food and ice are slowly melting.... fridge part is okay..this is... (More)
Answer
Samsung RM25 Refrigerator. Display flashing 88 88 to 98 99. The second 99 is actually reversed.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung RM255LASH Side by Side...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
